Meaning of' Camber at Vehicle Level'.
Old Oct 22, 2013 | 05:47 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
I am trying to ascertain the correct rear camber reading on my C Class w204.
WIS is confusing as it has different readings depending on "Camber at Vehicle level" (Please see attachment).
I would be grateful to know what this means.
The rear camber on my car is correct at +0.5' "Camber at vehicle level" ie -1.26'.(30')
Thank you.
John C.
File Type: pdf
Old Oct 22, 2013 | 07:54 AM
Glyn M Ruck's Avatar
Super Moderator
JC ~ the last time I saw Benz use the "Camber at Vehicle level" expression it meant the vehicle on a flat & level surface with a standardised load. This should be in the WIS somewhere.
e.g. Half a tank of gas & specific weights placed at each passenger seat & in the trunk/boot.
Old Oct 22, 2013 | 03:30 PM
Carsy's Avatar
Thanks Glyn.
So with my 'Camber at Vehicle Level' very close to zero my camber readings are correct.
i.e. there is nothing wrong with the rear axle camber on my car.
The inner wear on the rear tyres must be a feature of how I drive & the conditions I drive under. Strange that no one else on this forum experiences this ?.
My thoughts are, if I changed the rear camber with an accessory i.e. less negative ,I could very possibly change for the worse the handling dynamics of the car ?
I will try to minimise wear with tyre rotation. ( Not always easy when Michelin keep changing their bloody pattern.)
Thanks again Glyn.
Old Oct 22, 2013 | 04:10 PM
Super Moderator
You might want to have rear toe-in set to max spec.
Old Oct 23, 2013 | 02:23 AM
Carsy's Avatar
Thanks Glyn.
Here is what Tire Rack has to say on driving style/ wear :-
"Camber
The camber angle identifies how far the tire slants away from vertical when viewed directly from the front or back of the vehicle. Camber is expressed in degrees, and is said to be negative when the top of the tire tilts inward toward the centre of the vehicle and positive when the top leans away from the centre of the vehicle.
Since street suspensions cannot completely compensate for the outer tire tipping towards the outside when the vehicle leans in a corner, there isn't a magical camber setting that will allow the tires to remain vertical when traveling straight down the road (for more even wear), and remain perpendicular to the road during hard cornering (for more generous grip).
Different driving styles can also influence the desired camber angle as well. An enthusiastic driver who corners faster than a reserved driver will receive more cornering grip and longer tire life from a tire aligned with more negative camber. However with the aggressive negative camber, a reserved driver's lower cornering speeds would cause the inside edges of the tires to wear faster than the outside edges.
What's the downside to negative camber? Negative camber leans both tires on the axle towards the center of the vehicle. Each tire develops an equal and offsetting "camber thrust" force (the same principle that causes a motorcycle to turn when it leans) even when the vehicle is driven straight ahead. If the vehicle encounters a bump that only causes one tire to lose some of its grip, the other tire's negative camber will push the vehicle in the direction of the tire that lost grip. The vehicle may feel more "nervous" and become more susceptible to tramlining. Excessive camber will also reduce the available straight-line grip required for rapid acceleration and hard stops.
Appropriate camber settings that take into account the vehicle and driver's aggressiveness will help balance treadwear with cornering performance. For street-driven vehicles, this means that tire wear and handling requirements must be balanced according to the driver's needs The goal is to use enough negative camber to provide good cornering performance while not requiring the tire to put too much of its load on the inner edge while traveling in a straight line Less negative camber (until the tire is perpendicular to the road at zero camber) typically will reduce the cornering ability, but results in more even wear.
Even though they have some of the most refined suspensions in the world, the next time you see a head-on photo of a Formula 1 car or CART Champ Car set up for a road course, notice how much negative camber is dialed into the front wheels. While this is certainly an example of wear not being as important as grip, negative camber even helps these sophisticated racing cars corner better."
I now understand what is happening & am a happy camper.
Old Oct 23, 2013 | 07:45 AM
Super Moderator
Tire Rack is spot on as usual.
