snow tire size on c300 sport ?
Hi all
I have recently purchased the c300 sport 2010. Winter is coming in Canada I just got a set of winter tires the size is 205/55/16r on 16 rim. My question is this too small for the car? Some people have these on their c250 but not the c300.
On the MB manual it recommended the 17. Or some website suggested that
215/55/r16 for the c300 is the least. Any thought would be appreciated.
thanks
thanks
2004 Mazda6, 1993 RX7
This is the link for the 16" tires installed on a 2008 C300 Lux:
https://mbworld.org/forums/c-class-w...4-corners.html
You did not mention the 16" wheel offset, which could cause rubbing issues. The one I bought as a spare matched the Canadian 16" wheels. Your 215-55's are only .2" more radius for the tire, and should not be an issue. But all 16" wheels are not the same, regarding front caliper clearance (or interference).
Hi there thanks for the replies. I'm not sure what the wheel offset is. But the caliper and wheel are extremely closed with each other. I would say around 3-4mm aparts. I have not seen any contacted marked between them yet ..I have driven for last 3 days. But this still kind of freaking me out. Question is this safe
To have this as is this? apologize I'm noob when come to car.
Front wheel
![](http://s24.postimg.org/uc4km5f7p/IMAG0120.jpg)
back wheel
Front wheel
back wheel
![](http://s24.postimg.org/unm0ywvnp/IMAG0116.jpg)
2002 C230 Coupe & 2010 C300 Sport
2and2, which size tires did you end up going with...215/55-16 or 205/55-16? I went with the 215's...they're a little larger in diameter but it's a very small difference.
I bought them based off of Tirerack's recommendation. I should have likely gone with 205/55's like I had on my W203 but the difference in diameter is so small, I don't think there will be any problems - hope not anyway.
Tirerack is not the definitive authority on tires/wheels for MB cars. When I was looking at 16" for GF's C300, they said in US, 16" wheels would not clear caliper. I then bought a 16" wheel from them as a full speed/load spare for GF. Worked well.
Vic V is correct, the 205-55 would have a narrower tread, the correct diameter, and be a bit better as a snow tire, vs 215-55.
Of course it's better than a 17" 225-45 or 17" 215-50 series.
I'm confused in the mean time, the mechanic get me in doubt about the clearance between the caliper and the wheel told me that it would be ok to have as is this, but skeptical if any rock that gets in there and will damage the caliper. I was thinking exchange to the 17" set, the tires shop person was advised it perfectly fine as long these are clear no touch doesn't matter how close these are.
It is extremely difficult for a perfect sized stone to get in there, and if it did, it would not break the caliper. It may cause a harmless scratch on the wheel hub.
Same Question
Hi Guys,
I'm a noob to cars and to MB.
I am in the same situation. 2010 C300 4matic, my tire dealer recommends 215/55r16 instead of 205/55r16. Is there much of a difference?
As for rims, do these fit? http://www.tirerack.com/wheels/Wheel...Silver+Painted
Thanks!
Thanks!
