2013 c300 help!
Subscribe
Dec 10, 2013 | 09:28 PM
i have 2013 c300
when in reverse the passanger exterior mirror does not tilt
followed all instructions from the manual
what can i do?
Reply 0
Dec 10, 2013 | 10:15 PM
Are u sure the last button you pressed was the far right one(the passanger mirror adjustment one) before you engage the reverse?
Reply 0
Dec 11, 2013 | 12:18 PM
^ What he says.
Reply 0
Dec 11, 2013 | 08:51 PM
I had the same issue. Took a couple of times for this function to work. My independent MB mechanic said for some reason the c class does not seem to want to learn this the first couple of times. It works now and has been functioning as it should.
Reply 0
Dec 12, 2013 | 05:16 PM
Quote: Are u sure the last button you pressed was the far right one(the passanger mirror adjustment one) before you engage the reverse?
yes i have that button selected.
Reply 0
Quote: I had the same issue. Took a couple of times for this function to work. My independent MB mechanic said for some reason the c class does not seem to want to learn this the first couple of times. It works now and has been functioning as it should.
what did you do in order for it to start working?
Reply 0
Dec 12, 2013 | 06:40 PM
Quote: what did you do in order for it to start working?
Try this, start car and put in reverse gear, adjust mirror down to where you want it and then use the memory setting for your seats to confirm. Put the car in park and try it out...this worked for me.
Reply 0
Subscribe
Currently Active Users (1)
