Need help removing blower motor
All videos I've found are different setups from the w204.
All the videos Ive seen show 4 screws holding the motor in place. On my 2008 w204 I eventually worked out that the motor is held in place by twisting the whole motor body. Its so difficult to see upside down in the passenger footwell.
On mine there was a single retaining screw on the edge of the motor assembly, but this was missing. On the engine side of this is a tab which when prised up, allows the motor body to be rotated anti-clockwise to release it. Sounds easier than it is due to awkward location and the angled extra square air duct connection but got there in the end. Really stiff but managed to lever it using a small screwdriver against the tab without breaking it.
Once removed, found the motor was almost seized due to dust (5 year old car) rather than obvious water ingress as has been reported by others.
WD40 then grease to bearings (fan end is difficult to reach - I didnt take the fan off for fear of damage as it was stuck fast), and got it rotating freely. 12v applied to motor ran it fine. Moved brushes in channels - seemed ok.
Reinstalled and was pleased to find the seized motor had not burnt out the resistor pack and it all runs fine.
If it fails again I'll get a new motor (£ 140) and replace. I don't think a s/h one is worth it (£90) as it may fail soon.
Good luck
Last edited by Riviera1966; Dec 7, 2015 at 10:38 PM. Reason: impossible to attach picture
All of this helped, although I wasn't able to remove the blower something is hanging it up. It will not rotate all the way. I did manage to get some silicone spray into the lower bearing which reduced the amount of noise coming from the motor. That will have to do until the spring when I can try and remove the blower motor again.
Also check power supply to the motor with voltmeter before removing just in case its a fuse or something else!!
Many thanks to the earlier posts, most useful as I think the heater motor arrangement on mercedes is really pants!!
c1000 check control unit n47-5 (esp and bas control module)is defective
my banz give this code tell me about
Btw, I simply greased up the fan, I did not replace it, so the small amount of noise has gone away for now, we'll see how long it lasts.
