prefacelift NTG4.5
Old Dec 28, 2013 | 10:33 AM
Doa's Avatar
Doa
W205
prefacelift NTG4.5
i've always been told the NTG4.5 doesn't work in the prefacelift W204 (no idea why)
last week however i've seen A prefacelift W212 (so also the NTG4 normally) with a NTG4.5 retrofit and it works.
anyone with more insight in this? could it work on the W204?
Old Jan 1, 2014 | 07:55 AM
perdikoula888's Avatar
No, it will not work because of the different screen size, resolution and connector. Unfortunately it is extremely difficult to convert the smaller size ntg4 lower resolution with different connector flip up screen to the bigger high res ntg4.5 different connector to fit the flip up mechanism.
better change the whole dash instead
Old Jan 1, 2014 | 08:09 AM
Doa's Avatar
Doa
W205
hm so the screen is the only issue. thx
Old Jan 11, 2014 | 02:40 PM
Hugo4582's Avatar
C204 mercedes
Question there is no one who has more information?
hello, I'm new here and I'm from Germany. I have a w204 prefacelift. I want to change the old comand NTG4 to the new NTG4.5!
the new screen for the NTG4.5 I already have.
The NTG4.5 monitor can be converted into the NTG4 flip up frame. a lot of work but it works! Unfortunately I need help with the assignment of connections!
what do I need to change the plugs at the tag for NTG4.5?
sorry for my bad englisch - the translation comes from google!
Old Jan 11, 2014 | 02:59 PM
Doa's Avatar
Doa
W205
what about the COMAND unit? the front is different. how will you place it in the car?
Old Jan 11, 2014 | 03:30 PM
Hugo4582's Avatar
C204 mercedes
Whats the Problem? the front is cut according to...
The question is - what Pin on the Main connector i Must change?
Thanks...
Old Jan 11, 2014 | 03:36 PM
Doa's Avatar
Doa
W205
watch the pics and notice the difference
Old Jan 11, 2014 | 03:46 PM
Hugo4582's Avatar
C204 mercedes
I know!
but it fits into the fold! it must be cut right, left and up a bit from the plastic! I'll send pictures should I get it to work! can you help me with the wiring?
Old Jan 11, 2014 | 03:49 PM
Doa's Avatar
Doa
W205
i can't as i have never seen the NTG4.5 on a technical side but i'm very curious
Old Jan 11, 2014 | 04:00 PM
Hugo4582's Avatar
C204 mercedes
The ntg4.5 Display fits in the old ntg4 fit Up Frame, to! I Never Said it is easy!
On a German Forum i read it must be change two can-Bus pins but i dont know whitch one...
have you a Connectorplan of the ntg4 Main connector - Where every Pin on it Descript?
Thanks a Lot...
Old Jan 12, 2014 | 01:24 AM
theonidis's Avatar
W204 AMG PLUS 4MATIC
It have been done this retrofit in Germany, look the picture.
Old Jan 12, 2014 | 03:25 AM
Hugo4582's Avatar
C204 mercedes
Lightbulb
Its Look Nice, but this is the ntg4 from the e-class. This is Not the ntg4.5 with the sd-Card Slot!
Old May 7, 2014 | 03:16 AM
aznmode's Avatar
2010 c300
Do you have anymore info on this?
Old Jul 29, 2015 | 10:59 AM
Wilsonkpham's Avatar
W212-X204-W204
Nice Job!.
NTG4.5 on GLK 2009
