Door pin/part problem for 2008 C350. Please help!
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Hi all! I own a 2008 C350. Just recently, my door on the driver side of the car stopped locking. The door pin doesn't go up or down even if I press the lock or unlock button from my car, though there was still a slight movement. Thus, I removed the door pin because I thought it was just the pin causing it to be stuck, but that was a fail. What should be my next step? Do I have to remove the door coverings from the door to fix a part inside and how? THANK YOU
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
2013 C300 sport 4matic
Hi all! I own a 2008 C350. Just recently, my door on the driver side of the car stopped locking. The door pin doesn't go up or down even if I press the lock or unlock button from my car, though there was still a slight movement. Thus, I removed the door pin because I thought it was just the pin causing it to be stuck, but that was a fail. What should be my next step? Do I have to remove the door coverings from the door to fix a part inside and how? THANK YOU ![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
I read various posts and it seems like it's the door lock actuator that's the problem. I think exactly like the problem found here: https://mbworld.org/forums/c-class-w...#ixzz2q4UqwK9N. I have removed the panel, drilled out the rivets holding the metal panel. I now have trouble removing the door lock actuator. There is 2 wires wrapped around it and there seems to be a hook attaching the plastic cover to the door. Also, how do I remove the window regulator carrier? Thanks for the help
