Service A
Old Mar 11, 2014 | 10:18 PM
zachblev's Avatar
c300
Service A
Should I do service A or should just reset it so it doesn't come up anymore?
Old Mar 11, 2014 | 10:43 PM
Big Daddy's Avatar
C220 CDI SLK 200
You must do the service
Your oil will be pretty ordinary and if you just reset the indicator you could be up for a huge amount of cash for a new engine soon.
Remember oil is much cheaper than white metal
Old Mar 11, 2014 | 10:53 PM
zachblev's Avatar
c300
i've done a oil change just not the service.
Old Mar 11, 2014 | 11:03 PM
Big Daddy's Avatar
C220 CDI SLK 200
Then you can Reset the service indicator. An A service is not much more than a filter / oil change and inspection of tires fan belt brakes and general inspection of fluid levels
Old Mar 12, 2014 | 01:01 AM
adanmtxt1's Avatar
2012 C250
I just had Service A conducted and it was the oil and oil filter change, a cabin air filter replacement, overall inspection, a fuel injector cleaner additive, and topping up of fluids as required. Rear tires are wearing more heavily than the fronts (RWD C250) but everything was looking good.
Old Mar 12, 2014 | 01:23 AM
C300CA's Avatar
2011 C300 Sport, P1, MM, Wood, Heated FS, DIY rearview camera.
Same here last week, except I have not injector cleaner. Advisor said since it's a RWD car, three sets of rear tires to two sets of front tires is about the ratio in terms of wear.
