Can't fill gas (intermittent problem)
Old Mar 17, 2014 | 06:35 PM
suminub's Avatar
C-250
Hi
I have a C-250 that I purchased in CA in august. Have observed that every now and then, while filling the gas it clicks off even though its not fully filled.
I have tried different pumps in my area. So it isnt related to a specific pump.
My General observation is that 'Shell' pumps are more consistent with this problem as compared to 'Chevron'. So i first thought that it was something in the way the Shell pumps hose were designed that didnt work but then i observed the same behavior at a chevron this past weekend.
Wondering if any1 else has see this issue with the c-class?
TIA
Old Mar 18, 2014 | 11:24 AM
Drazil's Avatar
It's not you, it's the moisture sensor on the gas pump. Happens to me every so often too where you get a super sensitive pump and the splashback causes it to think the tank is full every 2 seconds. Annoying as hell. If I'm on empty, then I ease out the nozzle halfway, fill up about $20 and go to another station later. If you don't squeeze the trigger all the way it helps, but I get too impatient.
Old Mar 18, 2014 | 12:12 PM
MBc300elvis's Avatar
C300
Yea same happens to me only have one specific spot but I tell the guy hold it halfway and it works out good
Old Mar 18, 2014 | 03:55 PM
lohseh's Avatar
2014 Mercedes 300 C
I have had this happen also. Either don't put the nozzle in the filler all the way or slow the rate of fuel going into the filler neck. Some pumps are more sensitive than others.
Old Mar 18, 2014 | 07:32 PM
suminub's Avatar
C-250
thanks. just wanted to confirm if its not something wrong with my car. looks like its more of a pump/hose thing.
Old Mar 18, 2014 | 07:36 PM
Convict's Avatar
2009 C300
Happens to me also. Very very annoying. Have to turn the nozzle at certain angles and apply different kind of pressures to the handle. Reminds me of blowing into the Nintendo cartridge and not putting it in all the way.
Old Mar 19, 2014 | 05:45 PM
Matt-erhorn's Avatar
2015 C250 Coupe
I've had this problem and like Convict said, you kinda have to play with the angles and sometimes kinda lift and push it in more. Really annoying but luckily it's not every time.
