Which Wax to Use ? Available World Wide.
Old Apr 10, 2014 | 04:56 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
I need a new bottle of duco wax & would grateful of advice.
Longevity is a large factor as I will only use it twice a year.
My process is to wash & then wax once. No other bull sh#t.
The wax needs to have absolutely no abrasives.
Australian availability.
I see that Nulon Polymer Finish has long lasting protection.http://www.eziautoparts.com.au/nufinish-car-polish.html
Thank you.
JC
Old Apr 10, 2014 | 05:07 PM
Sportstick's Avatar
Another round of ICE
Can't address availability down under, but Collinite 845 was recommended to me on this forum, and has proven to be easy to use, with great results, and quite durable. Don't be put off if you see it described as "insulator wax". It appears to have been put to automotive use after its capabilities were discovered from its original purpose.
Old Apr 10, 2014 | 05:59 PM
terrencetong168's Avatar
2013 C300 4matic
If you want something durable, you should use sealant instead.
Try Klasse sealant.
Old Apr 11, 2014 | 04:29 AM
959drew's Avatar
c300
I use Collinite 845 is especially good on iridium silver
Old Apr 11, 2014 | 04:40 PM
Carsy's Avatar
Thank you all for your good advice. It is appreciated. I will research both products . JC
Old Apr 11, 2014 | 07:53 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Collinite 845 is nearly without peer in terms of durability for a wax. You should easily get 4-6 months use out of it. Sealants as mentioned are another good option which offers about the same durability timelines. It comes down to what look you're going for. Collinite will give you a warmer deeper look while a quality sealant (I'm a fan of Blackfire Wet Diamond) will give you a hard candy shine.
Old Apr 12, 2014 | 04:21 PM
Carsy's Avatar
Thanks AZN.
Ordered Collinite from Brisbane . There were 2 outlets in Australia & none for Klasse.
Old Apr 12, 2014 | 04:24 PM
Sentosa's Avatar
C200 Estate Kompressor W204, 2018 GLA 220d
Originally Posted by Carsy
Thanks AZN.
John
Can you give me the link?
John
Old Apr 12, 2014 | 05:25 PM
959drew's Avatar
c300
Carsy I recommend you clay the car and glaze it before applying the wax instead of just washing and then waxing. But if you are only going to wash then wax collinite is the better choice as a sealant may not bond well
Old Apr 12, 2014 | 05:48 PM
aussie e55's Avatar
2009 C 63
need the link
Originally Posted by Sentosa
John
John
can u give me the link also thanks
Old Apr 13, 2014 | 02:54 AM
Carsy's Avatar
Found it on EBay...http://www.ebay.com.au/itm/Collinite...item3a8a18fadb
Thanks for the tip drew. JC
Old Apr 13, 2014 | 02:59 AM
AZN Optics's Avatar
Word of advice with using Collinite. It had a tendency to harden while not in use. Before using, run some hot water in the wash bin with the closed bottle in it and let it soak for a minute. Then pull it out and shake till you get a nice liquid state. And make sure you go thin with it. Don't just glob it on like a cheap wax. It will make the buffing out process much easier.
Old Apr 13, 2014 | 10:01 AM
steven1888's Avatar
2008 c350 sport
Quick question, do you guys wash the car again after you clay bar the car? Or you simply wipe it dry and put on the wax?
Old Apr 13, 2014 | 05:18 PM
Sentosa's Avatar
Thanks JC.
Old Apr 13, 2014 | 09:22 PM
Akhafeez's Avatar
2004 C240 4matic, 2009 C300 4Matic
I need swirls outttt!
Old Apr 13, 2014 | 09:29 PM
95_993's Avatar
G63
^^^^^ no wax will remove swirls.^^^^
You'll need to polish swirls out first before wax
Old Apr 14, 2014 | 01:56 AM
AZN Optics's Avatar
Don't really need to wash again after you clay, but I do go over it with a QD.
Old Apr 14, 2014 | 11:02 AM
steven1888's Avatar
2008 c350 sport
ight, thanks. now all i need is a porter cable !!!
another question is what color pad i need?
orange to take the swirl out and yellow for wax/sealant
Old Apr 14, 2014 | 11:30 AM
AZN Optics's Avatar
Depends on what pad brand. Lake Country, Meguiars, 3M, Chemical Guys?
Old Apr 14, 2014 | 11:55 AM
steven1888's Avatar
2008 c350 sport
im planning to order something like this kit.
http://www.autogeek.net/wolfgang-por...l-remover.html
unless the other brand pad are better
Old Apr 18, 2014 | 10:16 PM
steven1888's Avatar
2008 c350 sport
@azn optics .. any suggestion? any body?
Old Apr 18, 2014 | 11:29 PM
AZN Optics's Avatar
Wolfgang makes some good products (huge fan of their Fuzion wax), but not so much on their polish.
Here's what I think on that kit...
PC 7424 is a good solid beginner machine. It's near impossible to burn your paint with that, but after a year or two of using it, you'll want something with more power for faster work. The more powerful machines (I use a Flex XC 3401) are safe to use though as long as you don't do anything stupid with it, but PC is definitely pretty idiot proof.
Pad wise, I'd stick with Lake Country CCS pads or flat pads, but not the 6.5 pads they have in the kit, and especially not with the PC machine because the PC doesn't have enough power to properly use 6.5. 5.5" pads are better option.
For polish, especially on the hard paint w204 uses, I'd recommend Menzerna Power Gloss and Power Finish. Those work well for our paint from my experience. Anther decent option are the Meguiar twins M105 and M205 which also work decently well.
The Wolfgang sealant are ok, but there are better options for the price. As mentioned, Blackfire Wet Diamond is my favorite sealant.
The Wolfgang detailer is nothing to write home about also. The best quick detailer I've ever used (I've used a ton) is still Finish Kare 425.
Old Apr 19, 2014 | 02:43 PM
J__'s Avatar
J__
2012 C200 CGI
i love mother's 3 step sealant wax. The carnuba smells amazing like banana icecream haha. I know there's new stuff out there but always loved that product for a nice shine without breaking the bank on Zymol
Old Apr 19, 2014 | 09:09 PM
steven1888's Avatar
2008 c350 sport
thanks for the tips guys.
Old May 2, 2014 | 05:05 PM
Carsy's Avatar
I used the Collinite Insulator Wax yesterday. It went on easily enough a panel at a time & looked good when finished.
Now to see how it lasts.
Thanks to all for your help.
JC
