Comand NTG 4.0 Retrofit Question
I've come across this: http://www.ebay.com/itm/Mercedes-C-class-W204-Comand-Changer-NTG-4-sat-nav-HDD-navigation-system-/271469306675?pt=UK_AudioTVElectronics_GPSSystems_GPSSystems&hash=item3f34d4e333
Seems like it has the unit, screen, and GPS antenna and says it's plug and play. I'm assuming its a European unit with maps of Europe. Seller seems confident it will work replacing audio 20.
Part no. is A 204 900 59 03
According to this thread, https://mbworld.org/forums/c-class-w...-retrofit.html, the part numbers don't match and there seems to be a bit more to it when installing the upgraded navi. (voice control, US maps, air vent, coding with STAR, cooling fan etc.)
Can some let me know and advise me if this unit will work on my car?
I'm about to pull the trigger, but want to make sure. Thanks in advance to all the members.
In addition to the unit, you also need a few additional parts.
The local MB dealer quoted me $4k for just the labor.
I mentioned already in my original post the additional parts, but...
Someone posted this:
You can re-wire the existing harness and do not have to put in the new air vent and buttons. I NEVER use mine anyhow. Depending on your location.. you can also get away without the blower.
GPS antenna... get one on ebay for $20. They work great.
EDIT: Be aware that you will almost certain have issues with SCN coding and possibly the MOST ring config (if you get a Euro model).
Bluetooth, radio, navi, voice commands, music register, memory card, DVD/CD player, everything works flawlessly. Fortunately, it has the latest firmware update and the newest maps uploaded.
Took about 1.5 hours for physical install, 2 hours to update DVD Map. Has the factory look and feel and I must say I'm pretty impressed with this system. Voice prompts are fast and accurate, internal amp sounds much better than audio 20, screen quality is great, navi is easy to use, maps look really good and user interface is clean. Love the extra multimedia entertainment additions. It's a real enhancement to the overall driving experience.
It does come with the buttons to open/tilt and close the screen but because I have the regular HVAC vents, I rewired them underneath the ashtray for a cleaner look. The cooling fan hasn't been an issue for me as I haven't had any issues. In engineering mode you can set the auxiliary fan speed according to temp. I also made a little opening in the central vents to allow A/C to flow down into the comand unit below.
I’ve managed to retrofit ntg 4.0 in my W207 but only thing outstanding is the cooling fan you mentioned. Can you please advise what parts I need and how to wire it accordingly. I found on ebay fan with conduit, where do I go from there?
Regards,
Alin
