TPMS Direct and indirect
Old May 6, 2014 | 08:04 AM
Alex_K's Avatar
W204 2012 C250 CDI
My W204 have indirect TPMS.Thesystem shows a message to check tires if there is low pressure. The system doesn't show the pressure of each tyre. Can we buy direct TPMS and show the exact pressure of each tyre?
Old May 6, 2014 | 11:58 AM
TheRulesLawyer's Avatar
C350
That's strange. My 2012 c350 shows it. Might be a firmware update? Id start by checking part numbers for the c250 vs 350 on the tpms.
Old May 6, 2014 | 02:08 PM
Alex_K's Avatar
W204 2012 C250 CDI
I found that the car have 477 TIRE PRESSURE LOSS WARNER. i speak with a person and told me that i must buy a system with an extra screen if i want to see the pressure of each tyres :/
Old May 6, 2014 | 02:35 PM
C350
The tire pressure displays on the gauge in the center of the speedometer for me. Do you not have that display?
Old May 6, 2014 | 03:09 PM
Alex_K's Avatar
W204 2012 C250 CDI
i have it yeap but its only show low pressure check tyres if there is a problem with a tyres.
Old May 6, 2014 | 03:32 PM
Doa's Avatar
Doa
W205
the indirect system uses the traction control system to check the tires so there is no real pressure check
Old May 6, 2014 | 05:18 PM
Alex_K's Avatar
W204 2012 C250 CDI
So if i put direct TPMS the system will show me the pressure?
Old May 6, 2014 | 05:57 PM
C350
Well EPC shows the system consisting of the tpms sensors in the wheel and control module that looks like its in the rear spare wheel well. Additionally there should be and antenna in each wheel arch plus associated wiring. Its probably prohibitively expensive to change systems.
Old May 6, 2014 | 09:20 PM
mflores342's Avatar
2014 C350 4M Sedan , 2014 GLK350 4Matic
Not sure if your car is prewired to detect the TPMS sensors on the car. Canada does not legislate direct TMPS on cars. Some cars have it, others just uses the ABS and traction control to determine if the wheel is low on air. I prefer this system. I use 2 sets of tires. One for the winter and do not have to worry about the added cost of putting TPMS on the winter set. You will need to replace them regularly as well as these units have a battery sealed in the housing and cannot be replaced. Not sure what the lifespan is.
Old May 7, 2014 | 08:50 AM
Alex_K's Avatar
W204 2012 C250 CDI
So its better to don't have direct TPMS in your opinion. Front this view you are right.
Old Jan 3, 2017 | 10:20 AM
Tkabc63's Avatar
2013 C63 Amg coupe
Hi , my c63 is equipped with Tire Pressure Loss Warner. Planning to upgrade my wheels from oem 18" to 19". Will i get any warning message? will upgrading to 19" affect traction control and sense a different diameter thus displays a warning message TIa
Old Jan 3, 2017 | 01:23 PM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
Agreed with this. It's much less of a hassle this way, especially when having two sets of wheels and tires. It does a good job too, it can detect a difference of about 5psi
edit: and I just noticed the age of this thread, oops
Old Jan 3, 2017 | 07:59 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
/edit your question was answered in the amg section.
