How many miles can I experct to get from a set of brakes?
My Service Consultant advised me that I have driven further than most on my first brake pads since they are 2 years old and lasted this many kms. He stated most people change them by the time they get to the first year service around 26,000km (C350 models) - guessing they have heavy feet.
Whoever quoted you $2500 for a 4 wheel brake job is looking to make a killing, I checked a couple places, dealer and independent, and highest I was quoted was $1600 for 4 wheels, and I specifically requested original MB parts.
That being said, I did manage to get a very good deal on the pricing of the actual brakes, brembo rotors, TRW pads.
Are you folks experiencing warped rotors (pulsating brake pedal), or are your service people recommending this?
Here's one set of factory pads on the rear with 82k miles. Fronts still have about 6mm after 110k miles and still going.
<img src="http://farm8.staticflickr.com/7430/10331478586_ca29f049d4_z.jpg" width="640" height="480" alt="IMG_8807">
My C250 has 70k on it now, but I bought it with 60k and the dealer installed new pads. I should be good for quite a while, I hope, at under 10k/year.
I normally change pads because of age and never because the markers start to squeak.
If i buy a car used, i always replace the discs with brakes because most places turn discs too fast, which leads to premature pad wear. Modern discs do NOT need to be turned when they are out of the box.
I would be grateful if you could explain about "Modern discs do NOT need to be turned when they are out of the box" as I do not understand what you mean.
As a rule, brake rotors do not need to be turned or replaced unless they become warped or excessively worn beyond their design specifications. All rotors have a minimum thickness, with which the rotor will be marked. Depending on driving habits, rotor/brake design and other factors, brake rotors can last hundreds of thousands of miles or far less. I've seen drivers destroy rotors in less than 5k miles, and seen others fail due to design/material failure even faster.
I won't machine rotors on my cars- the thinner they get, the more prone they are to warping. In my life I haven't had to replace rotors, either (knock on wood!), but would before machining them.
Prior to my CPO C250 coupe, I put 145,000 miles on the OEM pads/rotors on an Asian 6M coupe................
Again, good call - those two points you've made really set the bar.............
ez
Discs are 'turned' to make them smooth. This is to 'flatten' the surface that the pads touch. That's all fine and dandy, especially if the discs have some miles or have been exposed to high heat. When they are new and out of the box, modern discs do not need to be turned. You put them on the machine and spin them to make sure they are OK and that's it.
The reason this is an issue is because of the way that they are 'flattened'. the best way to describe it is imagining a needle on a record, that goes closer to the center as the record spins. Many shops set them to spin too fast, meaning there are grooves. If you set them so that the 'needle' moves very slow, you can get it so that the discs are completely flat. Most shops don't do this because it takes longer. If you turn them fast, you have grooves and those will eat pads and reduce surface area = reduced braking capacity.
I'm also quite pessimistic about shops because I know most people take short cuts when they can. If I don't see it with my eyes, I expect the worst.
I'm glad others have shared their mileage with pads. I don't drive like an old man at all
although as I get older the need to hustle from point a to b is becoming lost. I know people who have gotten 100,000k with pads and if you drive good, that should always be the case. But that means no turning discs if they don't need it, and not driving with a foot on each peddle.Tanktube, are you sure you got that right? I think you meant to say you replaced the fronts and the rears are OK. Normally, the front does all of the work. If not, you might have some issue.
On a side note...2k miles on the Akebono brakes and I still don't have brake dust. YAY!
