KEYS LOCKED IN TRUNK PLS HELP
Old Sep 15, 2023 | 12:48 PM
C0d3Sp4c3's Avatar
2013 C250
I was tempted to replicate the scenario in my 2013 C250 but for the life of me, the trunk just kept popping up! Guessed this is not possible on a vehicle equipped with a keyless entry.
Old Sep 15, 2023 | 01:15 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
There are only 2 ways to lock the key in a car with keyless entry:
1) You are in the car and lock the doors with the door buttons or the key;
2) The key is in the car and you lock the car with the OTHER KEY.
Old Jul 24, 2024 | 09:39 AM
Danales's Avatar
CLK550
I had the same situation and WAS able to get into the trunk without towing the car to MB. I disconnected the battery and waited 15-20 minutes. Reconnected the battery and then cycled locking and unlocking using the buttons on the dash (2009 CLK550). Not sure if this did the trick or if it was the fact that I was holding the Open Trunk button on the door when my friend tried the trunk latch and it opened. So, like someone suggested earlier, it doesn't cost anything to try and you might get lucky. I thought this had ZERO chance of working but it did. Hope it does for you as well.
Old Dec 1, 2024 | 08:04 PM
space737boost's Avatar
this didn’t work for me smh
Old Dec 2, 2024 | 04:10 AM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
If you can get inside the car then remove the rear seat and you should be able to un bolt the seat backs after the bottom is removed. You might be able to pull the cable to fold down the seat. Or stick something thru metal behind the seat back and press the trunk release button on the inside of the trunk.
Old Dec 2, 2024 | 08:41 AM
i seen on another forum someone did that and wasnt successful.
Just called 5 lock smiths and 1 said he can make me a hard copy key to open the trunk for $250 the others just told me they couldnt do it or only could open the door, called mercedes they said it will take a week because they dont make them at the stealership and will be $150
going for the lock smith option atp i cannot wait a week
