I have a 2009 C300 and hate the fact that the iPod/iPhone connection is in the glovebox. I tried to use a bluetooth adapter so I could stream music through my iPhone but that was not successful. So, I decided to relocate my iPod/iPhone connection to my ashtray. Since I don't smoke and my ashtray only collects used gum wrappers, I figured this would be the perfect place to have an iPod/iPhone connection.
Unfortunately, I didn't take a lot of pictures during this process as I just *****-nilly started the project one night when I couldn't sleep. But I will give you the basic steps and show you the aftermath...
Step 1: Remove shift boot and shift knob.
Step 2: Remove the console trim surrounding the shift knob to expose the entire area surrounding shift knob.
Step 3: Remove trim surrounding HVAC controls.
Step 4: Remove ashtray. Requires use of a torx screw driver to loosen two (2) screws. Also, requires you to put the car in reverse. Locate the gear-selector release at the back of the gearbox trim (mine was colored yellow). Push on it and select Reverse. Ashtray can then be removed.
Step 5: Remove glovebox. Requires use of torx screw driver to loosen approximately nine (9) screws.
Step 6: Remove iPod/iPhone cord from side of glovebox.
Step 7: Locate iPod/iPhone integration device (large rectangular black box with iPod/iPhone connecter attached). This should be adhered to the passenger side quarter panel area with some adhesive tape and velcro.
Step 8: Peel back the carpet in the front, passenger foot-well to expose the cable attached to the iPod/iPhone integration device.
Step 9: Peel back the carpet on the passenger side center console area to expose the side of the center console stack (radio/HVAC, etc).
Step 9: Relocate iPod/iPhone integration device to an area under the center console. (I was able to find an adequate spot that it fit into without much trouble. I think it fits in right behind the radios and under the AC vents).
Step 10: Thread the iPod/iPhone cord up into the ashtray area. This is a lot easier to do if you disconnect the iPod/iPhone cord from the integration device and tread it through the gap from the top. In other words, take the ethernet looking plug, place it where the ashtray used to be, and thread it through the gap between the console and carpet and reconnect to the integration device.
Step 11: Using the using a Dremmel tool, cut two holes in the ashtray so you can fit the iPod/iPhone docking station (shown below) into the ashtray. One hole must be in the back (to connect the iPod/iPhone cord to the docking station) and the other hole must be in the front (so that the docking station lays down flat, otherwise it will be tilted up a little and the iPhone won't have enough clearance to make a good connection). The holes will have to be wide and tall enough to insert the docking station through them. I was worried it would look unsightly, even though I took a lot of time to make it all look even with the Dremmel tool. But given the angles you sit at in the car, you can't even tell there are any holes behind the docking station.
Step 12: Using 3M or Scotch Tape velcro, secure the docking station to the bottom of the ashtray.
Step 13: Connect the iPod/iPhone docking station to the Mercedes' iPod/iPhone connector.
Step 14: Test, Test, Test! I found this out the hard way...
It is a power adapter. With it connected, I can recharge my phone when it's connected to the iPod cable. I think mine was a knock off of a more expensive one made by Schose (sp).
So you've used a geniune 30pin to lightning adapter cable? and the power adapter between just so it charges?
Yeah. The MB 30 pin iPod/iPhone cable won't charge the phone if you just use the 30 pin lightening adapter cable. That's why I have the power adapter. It is aggravating but it was the only solution I could find.
