BIG BANG - Drive shaft broke while driving
2 days ago I was driving to work at speed of 60 mph. Suddenly, I heard a big bang and the whole car shook, transmission fluid leaked out. I managed to pull the car over safely, called the tow truck because could not move the car. So today dealer gave me news that my drive shaft broke and caused damage to the transmission. Without even opening the transmission they gave me an estimate over 10,000 dollars. Dealership did not give me the cause why the drive shaft broke.
car is 2008 C300 with 105,000 with no prior history of any major repairs. 3 months ago the same dealership did the transmission oil and filter service and now they telling me that drive shaft just broke for no reason. It does not make sense to me. Any thoughts:
What is going on here? Are they telling me the truth?
Please help.
AJ
Please help.
AJ
2024 GLS450
Did the shaft itself break somehow, or did a flex disc give out?
They are a maintenance item as these cars get older - I'm not sure if it is something that is listed on the W204 maintenance schedule though.
2010 C200 CGI
It's possible for the drive shaft to break, especially if you're in an area that gets snow thus salt. It'll corrode the metal and over time weaken it enough to snap. Odd though that they did not see this last time during your tranny service as it should be included in the post service check no?
1 Post
C220 CDI SLK 200
!0 grand to fix? I would be looking to scrap the car at that price or searching the internet for scrap parts from wrecks. Car is approaching 7 years old. is it worth buying new parts one may ask. I have a leaking seal in my steering rack. MB quoted $7,000 for a new one. Got on the internet and they can be had from wreckers for $400
2024 GLS450
Oh! A universal joint snapped, not the shaft itself. It makes a bit more sense now.
I'm not sure I would call the car scrap - these cars still have a lot of value. You can find a 7g-tronic on the internet for a reasonable cost, I'm sure.
You'll probably need a new drive shaft too. At whatever speed you were going when that baby snapped I'm sure it is bent. Now if its not bad maybe you can have it re-balanced. Also if you choose to repair the vehicle, you still don't know what kind of damage this could have done to the differential. That's a nice chunk of change to add to the bill.
Super Moderator
For a UJ to fail catastrophically like that I would have expected some warning signs.
Alfadude (06-12-2020)
2010 Mercedes Benz C300 4Matic Sport
2010 C300 Broken Drive Shaft
Last week the front drive shaft on my 2010 C300 sport 4matic broke. 94,000 miles. I had been hearing a rumbling for about 2,000 miles, but accredited to worn tires. When a squeak started i suspected a failing wheel bearing. When i did a slow, walking speed right-left weave, after about 5 seconds i heard the "big bang." the drive shaft snapped off at the front universal joint. the shaft was also noticeably bent. the shaft was replaced and the car is shifting fine. I am concerned that there may be damage to the transfer case or front differential. Is there a way to tell if either of these are damaged, and what may have caused this? Love the car, and would hate to have to part with it, but the cost of replacing those parts is scary. Thanks
Wondering if the bolts and or just the U-joints are replaceable parts to prevent this from happening ? Not sure from your pictures, but it appears maybe the bolts snapped causing the joint to move
Looks like it died unfortunately from lack of good servicing,
the first sign is squeaking when taking off and red dust at the u joint.
2nd, is clonk when gently rolling on and off the throttle when driving, along with visible play in the u joint.
If I was entrusting a garage to do my servicing there would be a conversation about what is it they do check and if they includes driveshafts.
Outside of replacing tranny fluid....what else can an owner do?
I know that this is an older thread, but I thought I would at least chime in about the question asked by the PO "what else can an owner do?" The answer to that is to LISTEN to your car when driving, PAY ATTENTION to any weirdness at all that you might notice while driving, NOISES, VIBRATIONS, clunks, squeaks, etc. This is the car talking to you, telling you that something is not right. You must investigate these small signs asap, no matter how subtle they may be. Oh, and stop going to the dealer.... find a good independent MB Mechanic/technician. They will go much farther, and check many more things than the dealer will. All for a whole lot less money as well. Sounds too good to be true? Well it isn't.
SMG_CT (01-08-2019)
Please help.
AJ
Please help.
AJ
I feel your pain and have no suggestions, but more questions! I've got a 2012 C300 4matic and just had to have the front drive shaft replaced - to the tune of $2,000. I didn't notice any problems/noises until around the 12th of last month when I heard a click when turning and thought CV joints. I was due for an oil change so brought it to our mechanic who told me the U joint and drive shaft had failed and I'd only had 2wheel drive for who knows how long. As I was driving it home from the mechanics, I heard the click that brought me in there in the first place - called them and told them I'd bring it back in the morning. When I was driving it in the click became very loud and audible mainly through the center console. When they inspected it they said it was most likely the transfer case and that repair would run me $6000 - just for parts!!! Not sure what I'm going to do at this point... I only paid $13,000 for the car 1 1/2 yrs ago...regular services...why didn't they catch this problem on that expensive service b and could the noise be something cheaper??
DD
Hi AJ,
DD
DD
2014 tranny issue , drive shaft broke
Please help.
AJ
Please help.
AJ
http://lloyds.com.hk/sl320-broken-driveshaft-r129-1995/
My mechanic says that he's never seen this happen in his 40 years as a mechanic.
