Leaving my w204 for a month
Old Nov 11, 2014 | 08:48 AM
Akhafeez's Avatar
2004 C240 4matic, 2009 C300 4Matic
Hi guys, I will be leaving my car for a month in a parking lot. I was going to disconnect the battery and leave it, but the electronics will probably reset. Any thing else? OR i can leave it with my friend who will start it every week or so.
Thoughts
Old Nov 11, 2014 | 09:22 AM
Sportstick's Avatar
Another round of ICE
If all is in good order now, I wouldn't worry about parking for just a month. The effect is minor, but just having someone start it once a week actually does more theoretical harm than good, as moisture collects in the exhaust and if the engine doesn't run long enough to reach operating temperature, it does encourage corrosion. But, either way, a few starts, or sitting for a few weeks, the issue is minor. I'd just park it and leave it. The most noticeable effect might be some tire flat-spotting, which will go away after the tires warm up, but a few extra pounds of inflation just before leaving it might be helpful there. Don't forget to keep the pressure gauge handy so you can reset the cold tires when you return.
Old Nov 11, 2014 | 11:01 AM
steven1888's Avatar
2008 c350 sport
You should have a problem leaving it for a month. When on a trip for a month, came back, started it and it worked just like how I left it.
Old Nov 11, 2014 | 11:24 AM
Sportstick's Avatar
"a problem" or "no problem"??
Old Nov 11, 2014 | 11:31 AM
steven1888's Avatar
2008 c350 sport
Shouldn't have a problem and should have no problem. :p
Old Nov 11, 2014 | 11:36 AM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
If your battery is in good condition, leaving it for a month is no problem. I have left mine off for 2 months before and came back and it started right up. (It was parked outside under a foot of snow in freezing weather for most of that 2 month period).
Just make sure your battery is in good condition and fully charged (take a good long drive before you park it to charge it up).
Old Nov 11, 2014 | 11:50 AM
Akhafeez's Avatar
Alright, great thanks guys!
