Which fluids does MB dealership top off complimentry for routine service?
Old Dec 1, 2014 | 06:28 PM
c3002008's Avatar
C300, ML350
Hi,
My car is saying 'check coolant level' and when I checked I noticed that the level is low. When I take in my car for oil change will the coolant be part of the complimentary top off of fluids? Typically which fluids are topped off?
Old Dec 1, 2014 | 06:59 PM
LogicalApex's Avatar
2014 C300 Luxury
Complimentary? For my services I usually get billed for these.
Old Dec 1, 2014 | 10:46 PM
louiet3's Avatar
2009 C300 Sport Palladium Silver & 2012 GLK350 4matic Black
Originally Posted by c3002008
Hi,
It is not free. Check your bill and look for a charge for windshield washer fluid - 001 986 807 110.
Old Dec 2, 2014 | 08:17 AM
Drazil's Avatar
My car has also been saying "coolant level low" a few times in the last two weeks when it was really cold out. No more message by the time I turned the car off, or when the temp warmed up.
Old Dec 2, 2014 | 10:14 AM
c3002008's Avatar
C300, ML350
@Drazil-- mine said 'check coolant level' so I checked the level and it was low-- I could see the white area, normally you should only see black.
Yeah my MB dealer advertizes complimentary fluid top off , its probably a gimmick where they only top off washer fluid. I will just buy the coolant myself and do it -- is this the correct one--
Amazon.com: OES Genuine Coolant/Antifreeze 1 Gallon: Automotive Amazon.com: OES Genuine Coolant/Antifreeze 1 Gallon: Automotive
Old Dec 4, 2014 | 12:26 PM
Drazil's Avatar
Thanks, i'm gonna check it out... was ignoring it cuz after it showed up on the cold day, the following week the message never came up until another cold day hit. I figured the coolant volume went down due to the cold, and once the engine warmed up, the coolant expanded back to normal levels.
Old Dec 4, 2014 | 01:18 PM
xjmoe83's Avatar
2013 C300 4matic Sport
If its only slightly low, you can top it off with water. It will be fine.
