Added Rear camera 2011 C350 4Matic, Help!
Old Jan 12, 2015 | 10:39 AM
BenzAMX's Avatar
2011 C300 4Matic
I installed backup camera on 2011 C350 4Matic. It look great but i am kinda stuck.
Rear camera installed
Chrome camera house look match.
Clean wire. Trying to find to connect to Fuse box. I am stuck
What next? I look at green brown wire for rear light. Does this fuse box have plugin camera av? Or do i have to buy part?
I looked for right information about backup camera but Rick's forum at https://mbworld.org/forums/c-class-w...d-cyclops.html the images are gone. I m stuck.
Old Feb 7, 2015 | 12:36 PM
BenzAMX's Avatar
2011 C300 4Matic
So, I decided to do more research more about rear camera connect to comand system.
Took out and wondering what kind of Nav do I have?
Rear of Nav. What is blue slot for?
Its easy take out the comand nav system.
I didn't know It pre-wire for rear camera? I couldn't find it in trunk. So, I ll leave it alone and install other new wire to connect to Nav.
Bypass the black wire behind the panel to connect the ground.
Then red wire connect using this 15 fuse's wire of reverse white light.
It works! Its beautiful! I am happy about it.
Old Feb 7, 2015 | 01:11 PM
lemonstand's Avatar
2014 C63 507 Edition Sedan - Mars Red
Glad it worked. good job.
The way most people are powering their backup camera is through fuse #71, which is the cigaret lighter fuse. Use an "add a fuse" which can be purchased online or any autozone to avoid splicing factory wiring. From what I've read on here, there's been allot of issues when you splice the reverse camera wire (flickering screen, unstable power to the camera etc).
Old Feb 7, 2015 | 02:53 PM
BenzAMX's Avatar
2011 C300 4Matic
Thanks for headup about flickering screen. I ll look at it. If i use cigaret fighter fuse will make rear camera running all the time?
Old Feb 7, 2015 | 06:00 PM
lemonstand's Avatar
That's correct. It'll power on all the time when the engine is on. the camera uses so little power it really doesn't affect much. I've had mine set up this way for about a year now. No problem.
Btw. Where did you get your camera? That chrome casing is unique.
Old Feb 8, 2015 | 12:46 PM
BenzAMX's Avatar
2011 C300 4Matic
Good point. I ll take your advice and fix it. Thanks
Where I got rear camera from
Amazon.com : By lovelive-5 stars Selling CCD HD color universal Car rear view Backup Reverse camera night vision for all car such Audi BMW Nissan VW Opel Jeep Seat : Car Electronics Amazon.com : By lovelive-5 stars Selling CCD HD color universal Car rear view Backup Reverse camera night vision for all car such Audi BMW Nissan VW Opel Jeep Seat : Car Electronics
Old Feb 8, 2015 | 12:49 PM
BenzAMX's Avatar
2011 C300 4Matic
Any idea about this?
What is this blue slot on middle?
Old Feb 26, 2015 | 06:11 PM
BenzAMX's Avatar
2011 C300 4Matic
No one have answer about the big blue slot is?
Old Mar 9, 2015 | 06:33 PM
BenzAMX's Avatar
2011 C300 4Matic
Never mind. I figured out its sound port.
Old Mar 15, 2015 | 08:03 PM
Sincity's Avatar
I tried powering my camera by tapping into the reverse lt on the right side. It doesn't produce a stable picture. Has anyone been successful by tapping into the reverse light? I'm just concerned that I will prematurely wear out the camera by powering it on all the time.
Old Mar 15, 2015 | 08:40 PM
chazzz's Avatar
'05 MBZ C230K and '09 MBZ C350
Will that work on my 2009 C350?
Old Mar 15, 2015 | 10:38 PM
Sincity's Avatar
Will what work?
Old Mar 16, 2015 | 12:54 AM
chazzz's Avatar
Originally Posted by Sincity
Will what work?
I've always wanted a rear view camera in my 2009 C350. I have a COMAND system. Is it possible for me to hook up the camera to the COMAND (monitor) system?
Old Mar 16, 2015 | 07:03 AM
Sincity's Avatar
I want to say yes. I am using an aftermarket radio.
