2010 c300 battery
Old Feb 20, 2015 | 07:46 PM
yautsun's Avatar
2010 C300
2010 c300 battery
Hi,
I think my battery just died. I have a c300 2010 4matic. I have two questions:
1) Does 5 years sound about right for the original battery to die?
2) Can I replace the battery with something from Canadian Tire (I am in Toronto) such as http://www.canadiantire.ca/content/c...l#.VOfUgC59aao.
3) Do you know how much the dealer is going to charge approx. to replace the battery ? I called today but parts department was already closed.
I would prefer to go to the dealer but they are not opened on the weekend and it seems like all the Toronto dealers have a long wait for servicing right now.
I would appreciate any input or suggestions. Thanks in advance for the replies.
Old Feb 20, 2015 | 09:27 PM
babyboxer1's Avatar
2013 c350 Coupe
I replaced mine about 2 weeks ago, and it held up for 7 years. I took it to a tire shop because my tire pressure was low, and they kept the radio on the whole time. When it was time to go, the guy informed me that my car wouldn't start. They gave me a boost, but I figured after 7 years if 10 minutes of radio play was going to drain my battery, it was time to go. Being from Montreal, the weather has been rough this winter, so I didn't want to end up in a situation where it dies on me somewhere remote.
Anyway, I went straight to the dealer and it cost me $273 tax in. I don't know if Canadian Tire would have the correct battery, the OEM battery has a ventilation hose on the side. If you're OK spending the $209 for the battery you linked, IMO get an OEM one.
Old Feb 20, 2015 | 09:34 PM
babyboxer1's Avatar
2013 c350 Coupe
It's also not a difficult battery to replace. From the owner's manual:
- Remove the filter box
- Disconnect the battery negative lead
- Remove cover from the positive
- Disconnect the battery positive lead
- Remove the screw securing the battery
- Remove the battery support and bracket
- Pull out the battery ventilation from the battery (depending on battery arrangement in your vehicle model, the ventilation hose is located either on the left or right side of the battery)
- Take out the battery
To replace it, go in the opposite order.
Old Feb 20, 2015 | 09:45 PM
stratman1954's Avatar
2012 C300 sport
Five years is about right. I routinely replace mine every three. Cheap insurance not to get stuck somewhere with a dead battery.
Old Feb 21, 2015 | 12:14 AM
rander's Avatar
2010 C300 4Matic Sport
The battery in my 2010 E300 Sport 4matic died about 3 weeks ago at 5 yrs. 4 months and 48K miles. Replaced with an exact fit Duralast AGM battery.. Which received a very negative review in Consumers Report about a week after I bought it.
It's a very easy battery to change, especially if you remember to push the hood up completely. There is a video clip on You Tube showing how to do it (but he doesn't raise the hood completely)..
I strongly recommend using an exact fit battery versus "we can make it fit" version. The space in the box it pretty tight. The battery has to have a ledge at the bottom for the hold-down to grip. The battery is vented outside the box in a specific area and there is not a lot of slack in the cables to jury rig a battery with the posts in the wrong place.
Old Feb 22, 2015 | 09:29 AM
yautsun's Avatar
2010 C300
Thanks for the replies. I ended up pickup up the battery at the dealership yesterday for $275 taxes included, and changed the battery myself.
It was a relatively easy change although I found that I needed a relatively long socket set with good torque to get to and loosen the two screws holding the side plate.
