10 c300 4matic from drive shaft.
Hello everyone, had a u joint failure on front drive shaft. (Seems to be a common issue from what I have read) Ive got the flange off but I can't seem to get the drive shaft to slide out or down far enough due to clearance issues with the sub frame or exhaust. Is it possible to remove the front shaft with out removing a whole lot of other components.
Thanks,
Derek.
Thanks,
Derek.
