How to adjust headlight
Old Mar 23, 2015 | 02:28 PM
tetobasha's Avatar
2016 C300
Hi All,
I need to adjust my headlight beam .. the driver side aim (light) is shorter than the passenger side.
When I drive at night I can see the headlight range on my side is shorter than passenger side.
I looked for screw to adjust to raise the beam a bit but I don't see any screws or knob to adjust .. Please see the attached picture for my headlight and advice on how can I adjust my headlight beam. My car is 2008 C300. Thanks in advance ..
I don't see any screws inside the 2 holes to adjust. Plus I'm not sure how to remove the black plastic cover
Old Mar 23, 2015 | 03:24 PM
dudeitsmattx's Avatar
2013 C250 Sport
That is normal. The drivers side light should always be a little lower then the passengers side light. This is so you do not blind on coming drivers.
Old Mar 23, 2015 | 04:59 PM
tetobasha's Avatar
2016 C300
Thanks for your reply... Since mine is not little lower, is it possible to adjust it? if yes, from where since I don't see any screws. Thanks
Old Mar 23, 2015 | 06:33 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
There should be a white plastic screw hole for you to adjust your beam right behind the lowbeam port.
