Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz C-Class: How to Replace Brake pads/rotors
Step by step instructions for do-it-yourself repairs
Rotors & Brake Pad Question
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Hello guys,
I just completed my Transmission & Service A at the dealer and they said my rotors and pads are almost finished. They quoted me like $580'ish. I am a DIY'er so I was think I can just do it at home. The problem I'm finding is what are the correct brake pads/rotors that I need. I have 08 C300 Luxury. I was look online and prices range from $30-150 per rotor. What have you guys bought? And where did you purchase them? How hard was the installation? And I guess anything else that relates to it.
Thank you,
Thank you,
Hello guys,
Thank you,
Thank you,
They were cheaper to buy them from there and have them shipped here than what they were to buy here. Got them within a week. I have had the rear pads on for about 3000kms and there is negligible dust compared to the rears which will go on next week.
Hello guys,
Thank you,
Thank you,
I went with Akebo pads and oem rotors and dust is pretty much gone now. The grip is pretty much the same.
I did them myself and there's nothing out of the ordinary to change them. It's like any other break job. Just make sure you have torx bits for the calipers/carriers.
Also if you're doing the rotors too, just take off the bolts of the carriers and the calipers will come off together with the carriers. Two bolts per side, make sure you clean and scrub all the caked on dust from any moving point. That's it.
00 C200 & 00 C55 & 06 SLK55
I have the same car and the amount of dust that the OEM pads produce is worse than any other car I've owned. It was so bad that some cars had the rear oem pads replaced under warranty for excessive brake dust.
OEM = always dust
Akebono = great with NO dust
ZAYED,,
'05 MBZ C230K and '09 MBZ C350
My car was serviced at Mercedes dealer in Escondido, they used brake pads (and other parts) on my C350:
001-989-94-51 Brake Paste
005-420-13-20 Brake Lining (front)
211-540-17-17 Brake Wear Sensor (front)
005-420-42-20 Brake Lining (rear)
211-540-17-17 Brake Wear Sensor (rear)
So far, absolutely NO DUST (no black carbon dust) on my wheels. I was thinking maybe MB is using all-new dustless brake pads. Can anyone confirm that the part number 005-420-13-20 is dustless brake pads??
