TORQUE SPECS - TORQUE SPECIFICATIONS
*Rear Lower Control Arm Bolts: 50 Nm (36.9 lb-ft) and 90 degrees ( Axle Carrier - bolt near the center of the car), 80 Nm (59 lb-ft) and 90 degrees (Wheel Carrier - outer bolt near the wheel)
*Sheave Pulley (for C300 drive belt): 35 Nm (25.8 lb-ft) (idler pulley, part number A 272 202 10 19)
*Spark Plugs: 20-25 Nm (15-18 lb-ft)
*Wheel Lug Nuts: 130 Nm (96 lb-ft)
Real Lower Control Arm
Axel Carrier 50nm and 90 degrees
Wheel Carrier 80nm and 90 degrees
