Help needed! Changing transmission oil
By the way this is 2010 4Matic flex fuel
If I could avoid it I would not remove the crossmember .
Interested to know how you go.
John
Make sure the O ring is in place , that there is no dirt on the filter base from the exhaust pipe & the gasket faces are wiped clean with a non lint cloth.
Cleanliness is essential.
And the small seeping of oil seemed like it was coming from the back of the pan looked like the pan seal might've been letting some oil through. I wiped it as dry as I could let's see if it will be dry after new seal is in place.
Anybody else have input on the new filter sagging when you install it in the transmission? See pic above...
I should add that the filter I got from RMEuropean was not the OEM one but Elring Klinger brand. I'm assuming this is why it wasn't a snug fit.
Drove down the street.. although haven't gone past 3rd gear yet..Quiet shifting, no banging or knocking. Will give it a go on the highway tomorrow.
Anybody have anything go wrong after they did the fluid change before? What should I look for?
Or does it just take time for things to go wrong?
