Installed Parking Sensors....OEM style - not bad for $ 20.00
Old Sep 26, 2015 | 04:15 PM
aceman's Avatar
E500 4matic, 2014 GL320, 2013 C300, 2015 Stingray
So I bought a 2013 C300 for my daughter. While it has a backup camera, i still wanted som audible alert and decided to install the parking sensors in the rear.
Here's a pic of the system i bought from ebay, shipped from China for $ 20.00, came with everything pictured here, and 4 sensors. Make sure you get the system which mentions OEM sensor in the description.
First thing i had to do was get the sensors painted, they were black, so my buddy at my body shop did them for me. Then the install
1) Remove bumper. Basically 4 torx nuts on bottom of bumper, 2 bolts in rear, and 1 bolt per side. Also had to remove 2 trim fasteners on the inside of the rear tire wells. If you google C300 bumper removal, there are quite a few videos on youtube - really not that hard.
2) drill out the sensor holes (4 sensors are pre-marked on the rear of the bumper from the factory). Here's where i screwed up. The bit that came withe the kit is good, BUT - i put it directly into my drill (if i used an extension it would of kept the drill away from the bumper), and when i drilled through the bumper, my momentum pushed the drill into the bumper, and even though i had tape on the bumper - i damaged the paint around one senors. Anyway - if you do this - put a good thick (multiple layers) of tape so you don't scratch anything up, and use a drill extension.
3) Clean the inside of the sensor hole area thoroughly with a degreaser, and install the sensors (disregard the middle sensor arrow - that doesn't belong, the left arrow shows you the sensor) with the supplied adhesive double sided tape.
4) Run all the cables to the passenger side vent area (see arrow). Some folks go through a grommet there on the right, but since that grommet is behind a wiring block, i chose to go through this vent. There are cloth flaps on it so when you see it you're realize its very easy to go through.
5) Splice the power for the module to pin 8 on the rear passenger light harness (grey/yellow wire), connect the black to ground (there are a ton of ground connections in that rear area).
6) Run the speaker/display to the rear parcel area, and your done!
Any questions let me know - i liked this particular kit because it does look just like OEM. So far, after some testing, it does give a good audible warning as well as the camera so i'm happy with it. I may do this on the front bumper with a manual on/off switch for when you pull up close to a curb.
Aceman
Old Sep 26, 2015 | 09:48 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
Wow, nice job and great write up.
This looks like a great $20 investment
Old Sep 26, 2015 | 09:55 PM
PeterUbers's Avatar
It's a $20 investment for anyone that
- has a buddy at his body shop
- has the time and tools and wherewithal to remove the bumper
For everyone else it's $200-250
Nice job OP
Old Sep 27, 2015 | 07:26 AM
aceman's Avatar
Let me provide a little more info for anyone who may want to do it...
My buddy at the body shop provided me a $ 20.00 spray paint can matching the car. Instead of me spraying the sensors, he said his guy would do it while we BS'd....really not a big deal...so at the most its a $ 50.00 investment if you factor some freight if you buy the spray paint, color matched to your code, online.
To remove the bumper, you need a torx bit (forgot the size), and a 10mm socket, and a screw driver/flat blade to remove the trim fasteners inside the wheel well - that's it.
Time wise - couple hours max.
Thanks for the compliments guys
Aceman
Old Sep 28, 2015 | 07:04 AM
BenzManNy's Avatar
C300
Originally Posted by aceman
So I bought a 2013 C300 for my daughter. While it has a backup camera, i still wanted som audible alert and decided to install the parking sensors in the rear. Here's a pic of the system i bought from ebay, shipped from China for $ 20.00, came with everything pictured here, and 4 sensors. Make sure you get the system which mentions OEM sensor in the description. First thing i had to do was get the sensors painted, they were black, so my buddy at my body shop did them for me. Then the install 1) Remove bumper. Basically 4 torx nuts on bottom of bumper, 2 bolts in rear, and 1 bolt per side. Also had to remove 2 trim fasteners on the inside of the rear tire wells. If you google C300 bumper removal, there are quite a few videos on youtube - really not that hard. 2) drill out the sensor holes (4 sensors are pre-marked on the rear of the bumper from the factory). Here's where i screwed up. The bit that came withe the kit is good, BUT - i put it directly into my drill (if i used an extension it would of kept the drill away from the bumper), and when i drilled through the bumper, my momentum pushed the drill into the bumper, and even though i had tape on the bumper - i damaged the paint around one senors. Anyway - if you do this - put a good thick (multiple layers) of tape so you don't scratch anything up, and use a drill extension. 3) Clean the inside of the sensor hole area thoroughly with a degreaser, and install the sensors (disregard the middle sensor arrow - that doesn't belong, the left arrow shows you the sensor) with the supplied adhesive double sided tape. 4) Run all the cables to the passenger side vent area (see arrow). Some folks go through a grommet there on the right, but since that grommet is behind a wiring block, i chose to go through this vent. There are cloth flaps on it so when you see it you're realize its very easy to go through. 5) Splice the power for the module to pin 8 on the rear passenger light harness (grey/yellow wire), connect the black to ground (there are a ton of ground connections in that rear area). 6) Run the speaker/display to the rear parcel area, and your done! Any questions let me know - i liked this particular kit because it does look just like OEM. So far, after some testing, it does give a good audible warning as well as the camera so i'm happy with it. I may do this on the front bumper with a manual on/off switch for when you pull up close to a curb. Aceman
Great job. Something I may want to do.
Old Sep 28, 2015 | 07:58 AM
Nitalz's Avatar
W204 - 200CDI
Where did you install the display?
Old Sep 29, 2015 | 06:44 PM
aceman's Avatar
rear parcel area, by the speakers...
Old Sep 30, 2015 | 02:50 PM
edgalang's Avatar
Factory ordered 2012 MB C350 w/Dynamic Handling Package
Any questions let me know...
Aceman
off topic...
Is that a high mileage badge award left of the license plate?
Old Sep 30, 2015 | 08:31 PM
B Heals's Avatar
2010 C300 Sport
Awesome write up. Never thought this would be a consideration for me without buying a new bumper, but it is now!!
Old Sep 30, 2015 | 08:35 PM
aceman's Avatar
Edgalang -
that's not a high mileage emblem - its the dealership emblem...car only has 20K on it
Aceman
Old Feb 26, 2018 | 03:35 AM
xsever's Avatar
2012 C300 4MATIC Sport
Can you please provide the link from where you purchased this kit? Thanks.
Old Feb 26, 2018 | 04:18 AM
Doa's Avatar
Doa
W205
nice done. i installed a front camera next to the sensors
Old Oct 12, 2019 | 09:11 AM
Saiidraffoul's Avatar
mercedes benz W204 c250 2013
Pre-markes holes
Hi, is the premarked holes are from the inside of the bumper?
thanks
Aceman
Old Oct 12, 2019 | 09:50 AM
meazz1's Avatar
C250 2013
Great write up!!
Old Oct 12, 2019 | 10:27 AM
aceman's Avatar
Wow - shocked this thread came back to life. Yes - the sensor locations are premarked on the inside of the bumper.
Aceman
Old Oct 12, 2019 | 03:52 PM
Great
Aceman
oh thank you
appreciate it
cheers
Old Oct 12, 2019 | 07:40 PM
BF_JC230's Avatar
2005 w203 C230
Never EVER use a tool meant to punch a hole in wood, plaster or drywall.
Use a properly sized (most likely metric) step! It has a much cleaner cutter and a walk in...
