2012 vs. 2014 C250
Old Oct 1, 2015 | 07:52 PM
2014 C250's Avatar
2014 W204 C250
2012 vs. 2014 C250
What are the differences? I've read that the JB tuner is less effective or shows a less noticeable improvement on the 2013-2014 C250. Supposedly they have less of a lag problem? Running more boost? Heard the 2014s are more likely to throw a code with the JB tuner than the 2012s. Whats the deal?
Also a side note. I see attention assist enable/disable in my C250 and it is enabled, but never see a coffee cup. Is it in all new Mercedes or just an option?
Old Oct 2, 2015 | 11:41 AM
BlankProc's Avatar
Current: '19 E450 Cabriolet - Past: '19 C300 Coupe, '12 SLK350, '16 E350, '14 C250 (x2), '09 CLK350
I have a pretty much base (just P1) 2014 C250. Attention Assist is there, but it only comes on after several uninterrupted hours on the highway. I honestly find it annoying as I'm usually thoroughly caffeinated and not worrying about that.
Old Oct 2, 2015 | 03:40 PM
2014 C250's Avatar
2014 W204 C250
I have never seen it pop up just wondering if it is standard or an option. Car has premium package Panoramic roof and HID active lighting system. Just never have seen the coffee cup.
Old Oct 2, 2015 | 11:04 PM
W57thNY's Avatar
2013 Mercedes-Benz C250, Iridium Silver Metallic; 2001 Mercedes-Benz C240, Brilliant Silver Metallic
The coffee cup should be displayed if you have Attention Assist enabled. Mine's on the screen all the time. I'm not sure when it's supposed to alert. I've only noticed it go off after long fairly straight stretches of freeway driving, it's never gone off when I'm in the city, or on a fun windy road.
Old Oct 3, 2015 | 10:39 AM
jlr82's Avatar
2018 C300
If you have a 2014 C250 you won't have the coffee cup even if you have attention assist turned on. Mine has attention assist enabled but I've never once seen the coffee cup, my SA told me they did away with the icon to make room on the display for other more important items.
Old Oct 3, 2015 | 11:34 AM
aboutdamntime's Avatar
2014 C250 Luxury
I have a 2014 C250 and the coffee cup comes on after about 2 straight hours of highway driving.
Old Oct 3, 2015 | 12:28 PM
jlr82's Avatar
2018 C300
You're correct, the indicator only comes on when the attention assist activates based on your "driving habits", sometimes I think its just a timer that starts when you keep a steady speed above a certain set limit. I haven't had my W204 for long enough to even take a drive that long to see it come on.
Old Oct 4, 2015 | 08:38 PM
2014 C250's Avatar
2014 W204 C250
I found the coffee cup icon if I disable Attention Assist and then look at the "Assists Graphics" page. It show the coffee cup inside a circle and line across it indicating it's disabled.
Anybody have any opinions or input on the 1st part of my original post? Are the 2014 C250s less laggy/more responsive than the 2012s?
Old Oct 4, 2015 | 08:45 PM
W57thNY's Avatar
Might this have to do with the way the car's adaptive transmission has learned your driving style as opposed the 2012 that you drove? I find that if I'm driving an unfamiliar Mercedes-Benz, if it's not owned by someone I know, I'll do a transmission reset on the car so that it learns my driving style (dependent on how long I have the car).
Old Oct 4, 2015 | 08:54 PM
2014 C250's Avatar
2014 W204 C250
I haven't driven a 2012. I asking because it has been reported that the JB+ tuner which increases boost and lessens lag has a less pronounced effect on performance with the 2014s than on the 2012s. Also the 2014s will hit boost cut or overboost with a lower boost increase % setting. Why is this?
