First Mercedes 08 C300
The only thing I really do not like about the car is that is smells like the Crayola Factory made the interior.
Being a young male who hates having something anyone can buy and have the exact same car, I intend on doing a few small modifications.
Here is what I want to do if I can:
1) Install my old Pioneer double din and ditch Sirius radio (I stream my music and cannot connect my Iphone)
2) Find a set of aftermarket wheels without breaking the bank.
3) Lower the car for a more aggressive stance
4) MAYBE add the 2400 watt system I had in the last car (I dont want that $3000 system I pieced together to go to waste)
5) Add a few cosmetic changes such as a lip, small subtle spoiler, and touch up some paint
6) X pipe (Already ordered one)
I am sure there is more I will do and some that I wont do. I would hate to lose my heated seats just to have music worth listening too.
I will need advice along the way and I have been googling a lot of things within the past few days.
2008 with 21xxx sounds like it has been sitting, a lot. I'd have it inspected.
Unfortunately there are few aftermarket stereo options for the W204. There is a highly popular thread that describes improving the sound:
https://mbworld.org/forums/c-class-w...r-upgrade.html
Streaming and the iPod - Take your VIN to a Mercedes dealer and check if your 2008 headunit accepts the UMI (Universal Media Interface). This will give you multiple input options plus Nav in some cases. Admittedly the speakers supplied with the stock Audio20 W204 system is one of the auto industry's worst. However the Audio20 headunit has very low distortion output, sports a sophisticated A/D that allows the integrated parametric equalizer to function (a MB dealer can update the headunit's software to give you the EQ and the Aux boost), and the output D/A+amp combo is distortion-free up to clipping. A quality audio signal can be provided by just tapping the high level output speaker wires for both extra amplification or a subwoofer.
As for spending $$$ on sound - if you are going to rely on streaming MP3's as your primary music source, then NO amount of investment will improve the sound. Like they say: "Garbage in, garbage out". The noise will be louder, but not better. It is a fact that between streaming and MP3 compression, only 1/10th of the original musical information will reach the listener. Only music digitalized in Apple Lossless decoded with a 6th generation iPod Classic can equal the quality of an original AIWW CD played directly.
Just did a search and read up on that. I have only had my car a couple months now and have a lot to learn. Can't say I have noticed that in my car though.
*COMAND Operating Instructions*
Increasing the volume using COMAND
It may be the case that a device which is connected as an external audio source seems quieter or louder in the vehicle, or that the usual maximum volume cannot be achieved. The volume of some devices can be set
separately. In this case, start at a medium volume and then raise it slowly. This enables you to hear if the system can play the music without distortion even at high volumes.
Select Volume in the AUX display by turning the COMAND controller and press to confirm.
A menu appears. The dot indicates the current setting.
Select Standard or Boost and press to confirm.
Standard: the volume of the external audio source is adjusted to a standard value.
Boost: the volume of the external audio source is raised by approximately 10 dB.
