2010 w204 Central Gateway failure
They are charging $1100. They also said that they are not sure if it will fix the problem. They have to put that in and then check
I am sure I am getting ripped off.
Anyone knows the cost of a such a repair?
Seems like they should be pretty much bullet proof as they are just a switching hub with solid state components...anyone else know what may be a weak spot in them?
Pricing doesn't seem terrible but I'm not sure how involved it is to get to it and pop the new one out and the old one in.
airmatic wouldn’t work, had a few display malfunctions on the dash, including SRS, and occasionally the car did not want to start. One key symptom is I’m not able to communicate with many modules during a diagnosis scan
looking at the wiring/function diagrams, the gateway is the common link between all of these modules
they go bad a lot apparently in w211, I took the gateway out and found corrosion on the circuit board. Cleaned the corrosion but still having issues so it looks like another Cgw is needed. Hope this helps someone
