2012 c300 jump start damage.
As mentioned, you're better off being honest about the cause and working with your dealer to see if they can cover under warranty. Might be something as simple as a blown fuse though so check that out.
IMHO, it all depends on your approach to the situation. What's that old saying? "You get more with honey..." I hope all goes well.
You must be one of those that can barely afford to lease the car , than can't afford brakes or tires when they are due. Just to drive a "Benz"
if your not comfortable call another dealer that you don't go to and ask the question don't give any info and they will have no clue who you are.
The mistake you made was to make your problem known on a public forum. Best keep these matters "under the hood"
Glad it was resolved & a warning to all about jump starting.
The way I overcame an accidently drained battery was to remove the ign. key, connect up leads from another car then charge both batteries with a charger overnight. Disconnect leads & start as normal...no problems encountered,.
