Running cool 65-70c
Old Dec 27, 2015 | 10:39 AM
Jay Stivers's Avatar
2010 c300
Running cool 65-70c
I live in Arizona and ever since it has cooled off my 2010 c300 has been running cool @60- 70 c.. take awhile to come up to these temps and does not reach 80c. got a 0128 code.. possible bad thermostat? Stuck partially open? Fluid level is ok ,fan is not running ....thoughts.
Old Dec 27, 2015 | 02:30 PM
michail71's Avatar
2013 C250 Sport
Might be interesting to see if you can get a cable and log the coolant temp. That gauge looks nothing like the actual temperatures from the ODB-II data.
Old Dec 27, 2015 | 02:46 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
These thermostats fail open. You should find details here in the stickies.
Old Dec 27, 2015 | 03:38 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
I agree. Likely a bad thermostat stuck open.
Old Dec 30, 2015 | 01:44 AM
manny26's Avatar
2010 Mercedes c250 4matic
It is the thermostat stuck open I had this same issue last winter also , it gets stuck open sometimes in the cold days , it's doing it to me this winter also . I got the code once so far this winter but I'm not gonna bother changing it yet because it's not
A big problem it goes away once it warms up out. And the car engine light stays on even if the thermostat functions normally after it throws a fault code once .
Old Dec 30, 2015 | 03:18 PM
MaineSailor's Avatar
2008 C300 Sport 6spd man.
Plus one on the "not a good idea" comment!
Thermostats are there for a reason! Running an engine cold can cause numerous problems, not the least of which is corrosion on the cylinder walls. Replace your thermostat - it's not a big deal or expense!
Old Dec 31, 2015 | 01:15 PM
Alfadude's Avatar
2012 C300 4Matic
I agree. Best to correct issues when they are minor before they cause bigger more expensive problems down the road. This one seems like a no brainer. It is cheap and you have the advantage that can do it at your leisure.
