2.5" Xpipe instead of 2.25". A problem?
Now the w204 c300 if I am right is 2.25"?
Would there be a problem or anything bad if I get the guys to instal the 2.5" on a 2.25" pipe? Ofcourse they will do all of the necessary modification.
What do you guys think?
I heard it sounds great, but last thing I want is to loose low end torque if I remove those as well.
On the opposite side, a restricted exhaust will reduce top-end power by not allowing the exhaust to flow efficiently at higher RPM. It's simple physics.
Here is a sound clip of my xpipe:
Doubt anyone could say for sure unless you tested the flow over the full RPM range. Either way, the effect would be nominal.
