Just spent 3 hours replacing my headlight bulbs :)
On my old car it took me an hour the first time with my HIDs but I got the process down to under 5 minutes after getting some skill.
I replaced mine last night. To my surprise, the bulb clip is different than the clip I see on youtube. I had to twist the bulb to get it out rather the typical u=shaped clip. Mine was a metal piece clipped to the wire socket itself. I had to cut the HID bulb wires and pass them through the metal clip. YouTube says to drill an inch hole, which is a bit bigger than the actual aftermarket HID rubber grommet. I should have drilled 3/4" instead.
.....or maybe searched more for the right headlight model. What year/model did the eyebrow headlight come with? Mine does not have an eyebrow.
