M272 C350 idle speed question
Old Mar 30, 2016 | 11:42 PM
Jared26's Avatar
2012 C350 coupe
I'm wondering what your guys idle speed in drive are? I picked my car up from the dealership today for having the air oil separator replaced and halfway home at a red light I realized that my car was idling poorly, I can feel vibration in the brake pedal, in my seat and by putting my hand on the passenger seat, as soon as you accelerate it goes away and back to running smooth. It's idling at 525rpm right now and I swear it never idled that low although I can't remember and I know it idled perfectly before I took it in.
Old Mar 31, 2016 | 07:11 PM
Jared26's Avatar
2012 C350 coupe
Originally Posted by Plutoe
You have other issues and it sounds like you have issues with the throttle valve actuator which regulates the idle speed by adjusting it's position and taking into account the ECU adjusting the ignition angle-----which can only be adjusted with DAS---back to the dealer!!
The weird thing is it wasn't doing it before I took it in so I'm wondering if it could be something they did when they replaced the centrifuge.
They also washed the car after I requested them not too and swirled the **** out of it which I'm not impressed about.
Old Apr 2, 2016 | 04:36 PM
Sam.P's Avatar
'06 E55 / '10 GLK 350
What ? His idle speed looks fine and if its stable, what does this have to do with the throttle valve actuator ?
OP, are your RPMs stable? My car idles at 500-600 RPM too, so that's fine. To me it sounds like engine mounts since you're only complaining about vibrations at idle. Do you feel more vibrations in Drive/Reverse or when you turn the steering wheel ( while at idle speed, not moving )? Do they fade away when you go over 1000-1200 RPM ?
