Maintenance Quesiton
Old May 17, 2016 | 04:14 AM
myn8m3is8ndy's Avatar
2013 P31 C63 Coupe
I drive a 2013 C350 Sport Sedan. I was looking through the maintenance booklet and saw, "Replace rear axle differential fluid (limited slip differential only)." Can anyone confirm if this is the right fluid?? Thank you!
Amazon.com: Mobil 1 104361 75W-90 Synthetic Gear Lube - 1 Quart: Automotive Amazon.com: Mobil 1 104361 75W-90 Synthetic Gear Lube - 1 Quart: Automotive
Old May 17, 2016 | 09:43 AM
cvx5832's Avatar
325Ci, 325Cic, C300
You have a limited slip diff on your C350?
