Tire pressure
Old May 19, 2016 | 01:48 AM
Scimedna's Avatar
2013 c300 4 matic sport 2005 Suburban Z71 2005 G35 2 door sport coup
Tire pressure
Can anyone tell me the best pressure to run the OEM 2013 C 300 4 matic sport 18" AMG 5 star wheels usually I go -10% but as this is my first MB I thought I would ask !
Old May 19, 2016 | 10:00 AM
cvx5832's Avatar
325Ci, 325Cic, C300
Any reason you're running it soft? I also have those wheels and there's not much sidewall on them. I find that keeping it at the the door jamb pressure gives it the softest ride. Deflating a 35-series tire maxes out the sidewall deflection on bumpy roads and manifests as a harsher ride.
I have 33/38 recommended on my door. I've kept mine on 33/37 only because the car maxes out at 2.5 people.
Try it. Run it 10% under vs the correct pressure. You'll find the higher (recommended) pressure softer.
Old May 19, 2016 | 12:43 PM
Scimedna's Avatar
Much thanks
I will definitely run it as you suggest. i did notice something was off when I had to gas it and make a very quick move left and right and back left to avoid a major collision on the freeway (California drivers in the rain ) I felt a bit more body roll than I would expect that's what prompted me to look at the tire pressure . Now in all fairness I do also drive a suburban on 24"s (street tires) and a 05 G35 coupe that is dialed in fairly well that car sticks to the road ! I have only had the MB a few weeks ! Thanks I appreciate it !
Old May 19, 2016 | 01:23 PM
cvx5832's Avatar
325Ci, 325Cic, C300
Exactly! That mushiness is best explained on this vid :
Old May 21, 2016 | 09:57 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
My C350 has these rims as well and the door jamb calls for 36F 39R - this is too much, IMO. I am solo most time and 2 people max. I am trying out 33F 36R.
