P0245 Anyone?
Old May 27, 2016 | 10:27 PM
2014 C250's Avatar
2014 W204 C250
P0245 Anyone?
This code popped up today. I've seen the over-boost code, but not this one. "Wastegate Solonoid "A" Low. Have a JB+ and GFB Bloe Off Valve. Usually with over-boost I can just shut car off and back on and all is well, or clear the code. This P0245 remains though and limp mode with it.
Old May 28, 2016 | 11:33 PM
2014 C250's Avatar
2014 W204 C250
No one has seen this before?
Old May 30, 2016 | 10:19 PM
michail71's Avatar
2013 C250 Sport
I recall seeing this a time or two in the Audi/VW world. It usually is a rather straight forward code and points to a wastegate solonoid issue.
Old May 30, 2016 | 11:10 PM
2014 C250's Avatar
2014 W204 C250
I figured it out. Thanks.
Old May 31, 2016 | 12:26 AM
95Sinned420's Avatar
2016 S550
You should post what you figured out, so that others who have this issue could have some guidance
Old Aug 7, 2024 | 10:59 AM
ARS2024's Avatar
2013 Mercedes benz C250
[QUOTE=2014 C250;6818319]I figured it out. Thanks.[/QUOTE
What was the solution?
Old Aug 7, 2024 | 08:49 PM
cvx5832's Avatar
325Ci, 325Cic, C300
He didn't want to share. He got butt hurt
Old Aug 7, 2024 | 09:13 PM
TimC300's Avatar
I never seen that code before so did a little searching around. It appears a common cause is a worn/damaged wire or connection. Trace the wires may be a good start.
Old Aug 7, 2024 | 10:59 PM
ARS2024's Avatar
This helps thanks for sharing it!
Old Aug 10, 2024 | 07:37 AM
antboii's Avatar
2013 w204 c250 coupe & 2001 Dodge Ram 2500 24v Cummins
@2014 C250 what was the issue that caused this ?
