De-cat and Air/Fuel Ratio problem
Been reading these forums for nearly 10 years but this is my first post.
I have a W204 - C200K (M271 engine) with 215000km
I recently could hear an exhaust leak from my first catalytic converter (Cat). I also noticed a gradual decline in performance over the last year were it felt like the car was being 'held back' especially when taking off.
I then deduced that my Cats were probably blocked and since one was leaking I figured it was time to do my first mod and de-cat. So I de-catted yesterday and put in a 'mini cat' which basically fools the ECU so that the CEL does not turn on. The mini cat works like the normal cat but on a very very very small scale just at the post-cat O2 sensor
The car now feels 'free' and more responsive. No CEL on and everything seems fine. I decided to plug in my OBD2 scanner to confirm all's well and I found that my AFR commanded has now changed to 17.4. This used to always be 14.7 (stoich). My O2 sensors are all connected and apparently functioning the same as before the cat delete.
I am worried that this commanded value is too lean. My exhaust cat temperatures don't seem to have changed but my engine temperature was at 94 degrees Celsius this morning despite it being winter. My engine temperature is normally 81 degrees celsius during summer. This temperature increase must definitely be due to the lean mix.
What could have caused the AFR Commanded to change? As I understand, the cat delete should not affect the AFR since the O2 sensor that adjusts these values is before the cat. The post Cat O2 sensor is normally steady and is there to check if the cat is functional.
Hope you guys can point me in the right direction.
Kind Regards
Update:
So my engine temperature is actually fine. I didn't realize that I was at standstill with the car running for 45 minutes so this is expected. When moving, the car is a healthy 70-81 degrees C. There is no detonation/pre-ignition/knocking/pinging or whatever you call it.
I did however graph the precat O2 sensor and found that it is linear on 2volts as opposed to oscillating between 1v and 4v. This may be the reason my ECU is commanding at 17.4. I will check it this weekend with an old used sensor to confirm.
Final Update (Resolved):
So I'm a bit embarrassed....and glad I didn't fork out 6000ZAR for a new oxygen sensor. The ratio of 17.4 seemed vaguely familiar to me from back in my days at university and that's when it struck me...my vehicle profile on my scan tool was mistakenly set for Natural Gas fuel and not petrol. Natural gas stoich is 17.4. Once I changed the fuel type back to Petrol, my AFR was then calculated correctly as 14.7.
This is a lesson learnt regarding reading O2 sensors. The precat is a wideband sensor so its operation is significantly different to the post cat narrowband sensor hence the troubleshooting rules are different. Narrowbands use voltage to measure while Widebands use current which cheap scan tools don't show. However, wideband sensors do show a measured lambda reading. I will never pay attention to calculated AFR again which is based on your fuel input. Reading measured and commanded Lambda values would have pointed this silly mistake out a week ago and saved me a lot of worry:-)
In general, 400- and up cell cats are what you want for any car that needs to pass emissions. Many high flow cats out there are 200-cell, which are okay for looks, but will most times trigger the MIL (check engine light). They're simply TOO high flow, and don't do their job of burning off excess hydrocarbons (not enough surface area for the catalyst). Often, too, they're not built to a very high standard- not just to be cheap, but the aftermarket parts aren't required to meet the same warranty standards OE units are.
Knightmare, there is (in the US, anyway) no such thing as a 'low flow' cat. They haven't been manufactured for well over twenty years, now. Having spent most of the past fifteen years in the performance exhaust industry (US manufacturer of mufflers, headers and cats), I'm pretty up-to-date on this stuff, and just shake my head over much of what I read on the internet. Most people have opinions, which is fine, but I prefer to look at facts. Anyone reading can take what you want from this; I'm comfortable with my information.
Normal set up is your post cat sensor is either screwed into or just after the cat. My set up has the post cat sensor screwed into the "mini cat" which is then screwed into the straight pipe where the cat used to be.
The mini cat has the same catalyst in it as the original cat but is not in the way of the gas flow. The reduction reaction now takes place only for the gas just before the post cat O2 sensor.
My Post Cat O2 sensor is reading the same values as prior to decatting so the mini cat is working fine.
I just realized that my Precat O2 sensor seems to be stuck at 2v. This is the cause of my AFR being commanded at 17.4 despite any throttling. I am going to test this theory this weekend.
Things get old and die...fact of life.
I put in an additional silencer box where the second stage cat used to be to keep the noise down. There's no soot...but this mod should not result in or stop soot.
There is a difference in the smell of the exhaust since its chemistry has now changed. It's exhaust smells like older cars without Cats
This is also why you cannot use an exhaust sniffer to tune cars with cats on them. Tuning a car with a cat installed will need to be done with the sniffer positioned in the exhaust before the cat or with a pre-cat O2 sensor.
