Volume Control Malfunction!!
Old Jul 24, 2016 | 06:12 PM
Josh.A.Hussey's Avatar
2017 C43 AMG, 2010 C350 4Matic, 9 Motorcycles
Hey!
I searched but could not find!
My volume control knob doesn't work very well!
As in, I have to rotate it VERY slowly to change volume.
Steering wheel controls work fine!
Dealer said battery, had them change it, no luck!
Recently got a new alternator, also, no luck!
Any ideas?
Old Sep 22, 2016 | 09:32 AM
xEryx's Avatar
2019 E63s AMG
Lmao battery and alternator for a volume knob issue? what the ****. Anyways I have the same problem and am searching for a solution, I do have warranty though so it might be worth asking the dealer.
I'll do that first.
Old Feb 2, 2019 | 04:45 AM
Schaun1911's Avatar
2012 w204 c180 amg package
I'll do that first.
Hey guys any luck fixing the volume knob? I got the same issue on my facelifted w204
Old Aug 6, 2023 | 10:16 PM
pb39374's Avatar
2010 E350 4Matic sedan
Was there any solution for this?
Old Aug 7, 2023 | 12:01 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
The volume control uses solid state components that are difficult to repair unless you do electronic circuit board diagnosis and repair. Even if you find an electronic shop to work on it, labor costs would be prohibitive. It’s part of the head unit. MB wants $1300 + labor just for a rebuilt HU. The solution is probably swapping in a used $300 HU with the same part number as the one in your car.
Old Aug 7, 2023 | 05:33 AM
pb39374's Avatar
Thanks - So I assume any of the latest software updates and Nav map updates would have to get done again in the donor H/U once installed (assuming that the donor unit wasn’t already updated by the old owner)?
Old Aug 7, 2023 | 08:35 AM
JettaRed's Avatar
Veteran: Army
Or do nothing at all. I never use the volume control knob and always the steering wheel controls. Kinda hard to justify spending anything, let alone $1300 or even $300, to fix something semi-broken. But that's just me.
Old Aug 7, 2023 | 10:46 AM
pb39374's Avatar
yeah I am probably just going to leave it alone. Not worth the hassle.
Old Aug 8, 2023 | 12:00 AM
Odd Piggy's Avatar
I would assume the same. But I had Becker MapPilot nav, so it only used the HU for display. The Benz nav unit updates from CD if I recall correctly.
