Tire Issue...HELP!!!
If I am correct front's are 35 and rears are 41.
Either way this could be happening with punctured ties, or improperly mounted tires. Maybe the lip is not fully sealed, or maybe you have a dent on the inside of the rim that you can not see.
Pump all of them up, and measure each tire separately, and then check every day at the same time to see how much PSI to drop.
Make sure you reset the flat tire light when you fill up.
... Considering summer and 42 PSI probably doesnt make a difference, just wondering.
Pressure again - if it is ok - you have problem with one of the tpms sensors or the tpms computer itself. Dealer might be able to tell you if there is an issue with one sensor - If one tire is loosing air then take it to tire shop and get
Them to fix it ...bridgestones are good tires
1. Check your tire pressure at cold temperature. They should read a reasonable psi like what the door sticker says. I like 35 psi all the way around.
2. Once you should you tires are good at cold temperature. you need to reset the TPMS. This will let the system reset the default pressure.
3. Make sure you did get the right TPMS model for this car. There are many fake TPMS sensor out there.
