Successful LED high beam conversion
Any luck located that "easy fit" H7 setup??
Sorry, I meant same brand. The fog light mod actually uses an H11 bulb instead of h7.
For the high beams, the h7 bulbs plug right into where the bulb is normally inserted. The LED ballast/driver is small enough to fit inside the headlight housing and the cap can be put back on without issue.
Strange I can't find the H7 model on Enthuze's website. I believe Enthuze is actually a "rebrand" for this type of LED bulb which can be found under different brand names, I'll see if I can find a link for these bulbs elsewhere
2010 C350 Sport
http://www.ebay.com/itm/141980072796
http://www.ebay.com/itm/142414931693
Either of those would be easy to install. I recommend the seller though, good service and lots of quality items for sale.
Thanks..I can "stuff" everything in the headlight recess, right, so I can put the cap on? 60W vs 20W as far as heat buildup a problem with the C300 setup ?
Which one are you using...
Cheers,
Cheers,
2010 C350 Sport
The bulbs I am using are actually no longer sold by that seller. But they look almost identical to the ones in the first link, but they're silver and the LEDs are arranged in a line rather than a square.
Personally I would go with the ones in the second link since they're rated at a higher output.
