m276 cover removal
I remove the small screws and the v6 cover and th other two bolts underneath.
What other bolts have to be removed?
Thank you.
I attempted today again but gave up.
I can't find anything on the Web about removing the rear cover which by the way it is not a cover but the whole plenum to be able to get to the sparkplugs.
Two small screws remove the v6 cover and two 8mm bolts make it loose but then we need more.
It seems like the throttle body needs to be disconnected but the clamps are hard to remove.
Where can I find this info?
Does anyone have service manual that describes top engine cover removal?
Thank you.
There are two bolts under the center cover, and two more in the back, about 3 inches down, look with a mirror to get an idea, then use a small socket with extension and they should come right out. From there, it's a couple vacuum lines and hoses and it comes out.
It's not necessary to remove to get coils, just unbolt them and tilt them outward, then pull up and off.
