X-PIPE c350 or nah?
The car is already sported with some custom mufflers which the sound is already pretty impressive, can i make it louder with the x-pipe?
Somebody else have experiences with it?
How would much a x-pipe should cost with labor maximum?
And what kind of x-pipe brand should i take?
I should have done the rear cats.
Next is quad e63 tips and mufflers as I need more noise, this thing is quiet as a mouse.
for a $200 mod it was worth it for me. It's quite when you want quite, when you want to hear the car you can.
if you want extra noise just get an x-pipe and new mufflers, but for me an x-pipe was the perfect solution.
Can you do a quick clip of your car at startup and idle. I have a 350 but your engine and mine are exactly the same other than some tuning. It should sound very similar. I came from an 05 911 with sport exhaust and to me that sounded perfect. Forget the unmistakable sound of a flat 6, which is awesome but I loved the volume of it. It crackled and popped at start up then mild under 3500RPM then howled to redline. I regularly drive with the paddles and run into the 6K range in my benz in sport mode and just hate how quiet it is. I did the X pipe but I can't hear the car and I love to hear my car. Never had my windows up in my 911 and the radio barely on, just like exhaust sound and this is killing my soul. I can PM you my cell phone number and if you can shoot that over to me that would be great.
Caesar
Caesar
every one obviously has there own opinions, for me it was worth the $200.
and yes it does sound different on some C classes than others..... weird.
I did my x-pipe and found the sound increased when car is under load but on idle is quiet as a mouse.
I just received my quad tips and the car goes for some work next week.
We will test without mufflers first and if too loud we are putting some high flow mufflers.
x-pipe by itself was not enough for me.
What i would recommend is second cats and x-pipe first and then mufflers if that's not enough.
I will post pictures and sounds after my work is done.
