2008 W204 C350 Battery failed
Battery bust for sure. Charge again just to keep some charge in it.
New battery ordered previous day(Accepted old age).
Just want to make sure about the procedure replacing the battery.
The W204 manual say:
1- to disconnect NEG(Earth) 1st, then disconnect Pos.
2- to remove clamp.
3- Remove battery.
4- Replace battery.
5- Tighten clamp.
6- Connect Pos.
7- Connect Neg(Earth) last.
Question:
After doing this what can I expect to be not fuctioning and will needs a reset-?
I have read about using a booster in parralel while replacing battery as to not loose power to electronics on Youtube(The guy was quite serious about this method.)
I have asked the local auto electrician which is clued up I would say and they said no need on this car to use parrallel power. Another shop also working on Mercdeses also confirmed this.
Have not asked the dealer, far away in any case.
Printed on Battery.
A 000 982 22 08
12V 84Ah 700Aen
Q001 ZGS2
Removed the stickers and found the filler caps. The cells are covered with water. All the cells except one gasses easily when charged.
Question:
I just want to know if this terminal remove method is safe as described in manual.
Battery replaced with Varta F19 Silver Dynamic 12V-85Ah-800A(EU). Car started like never before since new. I think my rarely nonstart problem will be gone as well as that it never started after same predictable turns as all other vehicles I owned. Think orginal battery was "partially" faulty all these years, since 1st service I would say.
Sleep mode bonnet open.
Remove cover
Remove NEG-Earth.
Alarm went off....let it run till silent.
Remove POS.
Remove clamp.
Remove battery disconnect vent.
Replace battery connect vent.
Reposition POS.
Reposition NEG.
Alarm went off, cleared immediately with key.
Car started without problems, no messages etc.
Charge new battery further with CTEK 3.8.
....Have not checked mirrors, windows ot sunroof, radio yet.
I can't believe the OG battery lasted 8 years and still has some life left.
I bought some $10 thing that has a 9-volt battery and you plug into your 12v receptacle and it will save your car's pre sets so you don't have to reset everything after swapping your battery.
My 2008 C350 was without power for more than 24hrs during the removal and installation process. After installation of the new Everstart battery most previous settings including the correct time were automatically restored. I will find out over the next week if any settings need to be reset.
JR
Hopefully my 3yr replacement warranty will kick in and give me at least 5-6 yrs with the EverStart.
Thanks for the AGM recommendation.
JR
Check out this link.
https://www.walmart.com/ip/Platinum-...ttery/40685088
JR
