W204 2013 C250 Radio Removal
I did find a European YouTube video showing the procedure for removing the head unit from a facelift W204. The last step is to put the key in the ignition, turn to the second position, move the shifter to D, then turn the key back and remove from the ignition. At this point in the head unit can then be extracted. The problem with this is that with the automatic you cannot remove the key from the ignition with the shifter in the D position. You have to place the shifter in park before the key can be removed. I've tried various combinations of the shifter position and the key but still cannot release the head unit.
Anyone know the secret?
