No Heat C350 2009 - Blower Heater Spins
Old Nov 22, 2016 | 12:37 PM
Nicholi2007's Avatar
2015 C400 Tenorite Gray
I have a 2009 C350 with 86,200 miles. Temp is above 80. I took the cover off over the battery and the motor spins and the cover down.
Just cold air coming into the cabin.
Q. Is there another flap somewhere that could be shut? Any help is appreciated. Thanks
Old Nov 23, 2016 | 11:34 AM
Colin G's Avatar
2008 C-230 4Matic Sport
Could be time for a new thermostat and a coolant flush.
Any car I have owned, when the heat stops blowing the culprit is usually a thermostat gone bad.
If you can DIY stuff a thermostat change is about a 2 hour job. More if you take your time, have a beer or two, ect ect
You will save hundreds doing it yourself.
Hopefully it is something simple but I am betting on a bad thermostat.
Old Nov 23, 2016 | 06:46 PM
It's been a few years since I changed the coolant. Does that affect the life of the thermostat?
Old Nov 23, 2016 | 06:53 PM
SA sent me this text message:
If the engine is warming up, t/stat fine. Maybe a heater valve, of air blend door in heater case...
Old Nov 23, 2016 | 07:03 PM
It's likely the Heater Control Valve. Damn. This W204 is even less reliable than my W203.
http://www.pelicanparts.com/techarti...placement.html
part for my car is
http://www.mboemparts.com/mercedes-b...-control-valve
Old Nov 24, 2016 | 10:29 AM
Colin G's Avatar
I'd be happy personally if it is the heater control valve and not a thermostat.
Much cheaper and easier to replace the valve than the thermostat.
I mentioned a coolant flush earlier since if you are removing and replacing a thermostat, you may as well flush and put new coolant in.
Old Nov 24, 2016 | 10:35 AM
Seems like it although the MAF needs to come off. Hopefully that's not too bad.
I've have a lot of parts fail and I'm not even at 100K yet.
