Mercedes Battery Alternative - Exide
Old Dec 18, 2016 | 01:11 AM
Nicholi2007's Avatar
2015 C400 Tenorite Gray
I bought a CPO in September 2012. On Feb 25, 2014 the battery was replaced as it was failing.
I complained to the dealer. With a little arm twisting, a new one was installed for $165 installed, no labor charge.
Fast forward to today, Dec 17, 2016. After doing yet another recall on my car (SRS) the battery failed the stress test.
The fan had been sporadically revving like a turbine for the past three weeks. I decided to see if this might be the cause of this gremlin. So far so good.
So after two replacements and not even 4 years, Mercedes Batteries seem to suck. I called the dealer and they only warranty for two years.
I decided to go with Exide Edge FP-AGML4/94R. Here's what I got.
  • 4 years free Replacement Warranty
  • 7-Year Prorated Warranty
Cost to install including tax was $228.84. Home depot charges $235.00.
Q. Has anyone used this brand?
Old Dec 18, 2016 | 03:55 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
My OEM battery has been in the car for 9 years,so I have no complaints. It is a Varta AGM 70 amp hours, made in Germany .
I am interested to know what brand the batteries were that failed?
Your Exide Edge in an Absorbed Glass Mat battery which looks impressive. http://www.exide.com/Media/files/Dow...n%20spread.pdf
I cannot see you going wrong with your choice.
I would however make sure your charging system is operating as it should.
Old Dec 18, 2016 | 09:55 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Indeed it seems like a safe choice for a battery, but the batteries Mercedes uses do not suck. There is something going on with your car in particular.
Old Dec 19, 2016 | 01:24 PM
tekfoc's Avatar
Veteran: Army
18 E63S
this is the exact battery i installed on my 12 c300
great battery I paid 179.00 I installed it myself.
it's a fantastic well known brand
Old Dec 19, 2016 | 01:26 PM
I don't know the brand. I called him back and there were no markings. All he could find was original Mercedes on it
Old Dec 19, 2016 | 02:33 PM
Spoke with the SA and he says it's not that unusual. They have new cars with batteries that fail in two years. They want to do a parasitic test for $178.
How long have you had the battery in your car for?
Old Dec 19, 2016 | 03:07 PM
chrisridebike8's Avatar
'10 C63
My stock MB battery lasted 6 years. I just replaced with a Bosch AGM battery from pep boys. Purchased online and picked up in the store. Took me 5 min to install. $165 and 4 years replacement.
Old Dec 19, 2016 | 03:18 PM
I think these SAs are full of hot air. At least I did not pay dealer price. Jeez.
Old Dec 19, 2016 | 03:25 PM
Colin G's Avatar
2008 C-230 4Matic Sport
The battery on my 2008 just gave up the ghost so 8 years is pretty good I think. I bought a Northstar battery made by Odyssey for a replacement. Kind of pricey but lots of power. Installed myself in about 5 minutes.
Like most routine maintenance procedures on this car, I am always surprised how easy they are to do.
Old Dec 20, 2016 | 12:37 PM
nelson g's Avatar
C300 4matic
If you have AAA you can have them run the test for you. Two weeks ago my car would not start I called AAA and they tested the battery, the charging system and also told me if there was anything running that would drain the battery. The batteries cold cranking power was low and it was a five year old battery. Cost for the test zero. I had them jump start me and went to the dealer and purchased a new battery $160 and I installed myself.
Old Dec 20, 2016 | 01:12 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Trust me when I say having this done on a star system is leaps and bounds better. There are many things that stay on in the car for 1 -15 min after the key is removed and door is shut. Star can pinpoint thing that should not be on.
Old Dec 21, 2016 | 01:07 AM
LILBENZ230's Avatar
My car is 3.5 years on the stock battery. Battery in my W203 lasted 7. Battery in my W211 was 6.
Old Dec 21, 2016 | 04:42 PM
Just got the car back from the dealer. Evidently a sensor is connected to the negative battery cable regulating how much the battery is charged for fuel economy. They found no drain issues. Internally Benz replaced this part with another. I guess that's benz speak for we have a quality issue with this part.
  • NOTED AFTER MARKET BATTERY
  • INSTALLED IN VEHICLE. CONNECTED BATTERY CHARGER, PERFORMED SHORT TEST,
  • NO RELATED CODES. PERFORMED AMP DRAW TEST, CLOSED ALL DOORS, LOCKED
  • VEHICLE, CHECKED QUIESCENT CURRENT WITH CAN ASLEEP, FOUND OK AT
  • 0.17AMPS. CHECKED BNS SENSOR READING IN REAR SAM VERSE BATTERY VOLTAGE,
  • FOUND DIFFERENCE OF 0.6V. REPLACED BMS WITH NEGATIVE CABLE DUE TO
  • ELECTRICAL FAULT/NOT READING CORRECTLY. CLEARED CODES. ROAD TEST AFTER
  • REPAIRS, OK. 1908 GOODWILL
They replaced with part no. 000-905-27-02 A BATTERY SENSOR
Driving the car feels better. It seems more responsive. cranking seems better too.
Old Dec 21, 2016 | 11:02 PM
Carsy's Avatar
Thank you for the interesting follow up. I wish everyone did this.
Could someone tell me what BMS means ?.
Was the battery sensor not allowing the alternator to charge the battery?
Old Dec 22, 2016 | 06:13 AM
handyman762's Avatar
2011 W204 Avantgarde bussiness edition
Battery Management System (BMS)
Old Jan 10, 2017 | 01:06 AM
My understanding is that it was not working correctly. Therefore, it was limiting much more the frequency of when to be charged.
Old Jan 10, 2017 | 11:46 AM
Just spoke with the mechanic and he says the previous sensor did not recognize city driving so it was not charging. Updated part does.
Old Jan 10, 2017 | 11:49 AM
That's a great price. I suspected I was not getting much of a deal, however, I was in a hurry and did not want to have to deal with disposal of the old. Will pep boys take the old one?
Old Jan 10, 2017 | 10:18 PM
superangrypenguin's Avatar
A car
Holy moley. 9 years?! Is it really hot or cold where you live? I typically replace batteries after 5 years. Is this necessary on the W204?
Old Jan 10, 2017 | 10:54 PM
Carsy's Avatar
It is a mild temperate climate on the coast. No ice/snow/frost . A cold day in winter is 15'C & a hot one in summer is 35'C.
The car has only done 98,000 km.
A new Varta is approaching A$400 so I am glad I do not have to buy every 5 years. May did the death adder out of my pocket next year & buy a new one
