Winter tires for C350 sport 2013
If you're looking for good all-around performance, I suggest Continental DWS06. The "DWS" stands for "Dry, Wet, Snow" and I have used them in snow before and they are excellent. Of course, we don't get too much here where I live.
2019 911 GTS / 2016 X3 / 2015 E63s / 1993 RX-7
Any of the big name winter tires will do very well.
Nokian Hakka
Michelin X-ice 3
Blizzak WS80
Conti Extreme Wintercontacts
Goodyear Ultragrips
They all have high performance 'versions' which will give up ice/snow traction but be better for 'higher speed drivings' and me more responsive.
I prefer the Michelins and have them on a few cars, the others have Goodyears (mainly because the Blizzaks and Michelins were out of stock when I needed a set, late in the winter).
For the winter I run a square setup on my c63 so I can swap the front to the rears. You definitely give up width/grip in the rear, but I don't get on the throttle in the winter.
My wife has a square setup Michelin X-Ice on her C300. The acceleration and handling in her 4matic is superior to my C63, but I feel that the X-ice have more ice grip when braking than my Goodyear Ultragrips.
Nokian Hakka
Michelin X-ice 3
Blizzak WS80
Goodyear Ultragrips
Nokian Hakka
Michelin X-ice 3
Blizzak WS80
Goodyear Ultragrips
For the winter I run a square setup so I can swap the front to the rears. You definitely give up width/grip in the rear, but I don't get on the throttle in the winter.
Nokian Hakka
Michelin X-ice 3
Blizzak WS80
Goodyear Ultragrips
I run a square set of Nokian Hakkapeliitta R2 on separate set of 17" wheels.
They're the best winter tires money can buy, but might be overkill if you don't get much snow.
My "summer" tires are the Conti DWS 06s that were also recomended. While they're fine in snow (probably the best you'll get from AS tires), they don't even come close to dedicated snows when needed.
I am running Yokohama ice guards because the were the only studless winter tires available in staggered setup (225 front,255 rear). So far, so good
Other option is to go thru tire rack order snow tire and wheel package for car. They can ship to installer in your area. You can store your OEM wheels and tires to use rest of year. My Dad did this when he lived in Connecticut and had an Infiniti Q45 in the early 90s.He had two sets of wheels and tires. He also did the same with his e class Benz when he lived in Ohio.
With no ice and a little snow in Arkansas - that's why I recommended an all-around tire like the DWS06. I don't think an Arkansas car needs a dedicated set of winter tires and wheels, but to each his own.
Jake@PKAuto (12-21-2016)
A staggered setup is nice, but a square set up allows you to rotate front to rear on the same side.
But if that doesn't matter to you then a staggered setup preserves the balance/grip in the rear
