W204 AIR SUSPENSION HELP
Whats up guys, new MB owner. Looking through the forums can't seem to find too much info on bagged c300's and what info is available seems vague or outdated. To start I'm working with a 2008 C300. To be completely honest I'm not sure if its 4matic or RWD, paper work doesn't specify and I'm still searching on how to validate that. Haven't been able to get underneath the car yet either. What I'm looking at is
https://www.amazon.com/2008-2011-Mer.../dp/B01CRSSOO6
and
https://www.amazon.com/Mercedes-Benz.../dp/B01FWTZJWM
Now these both claim to be direct bolt on kits with no fabrication necessary, in your guys experience is this true? Ive also read that you would need after market sway bar end links as well. Which i can't find too many options for. All in all I'm just curious to see what setups you guys are running and what complications you had with installations. Any help would be greatly appreciated!! Btw my C300 is bone stock. Also, I've read through the air suspension threads on here and forgive me if i missed the info I'm referring to but i couldn't find it. Just seen people fabricating their own kits back in 2012. Obviously theres new products on the market and just seeing if anyone has had experience with them.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
and
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
The strutmasters kit actually allows you to completely remove the air suspension from your vehicle. Also they use a double action spring which give the vehicle a significant amount of stablity reducing the need to add a sway bar.
There's not many bagged w204's that frequent the forums they are all on instagram. I know 3 dudes that run the basic d2 air suspension on their w204s and they love it. It's a manual switch thing and they are pretty reliable compared to the other digital management systems. I've heard of all sorts of horror stories of people running digital management running into situations where the car would air out completely when it's not supposed to. In any case you gotta find if you are RWD or 4matic...the rears are the same, but if you have 4matic, you will need custom front struts. I'd try and find some people who run the setups you want and ask them. The D2 kit is direct bolton as long as you have RWD.
off the top of my head these three w204s run the basic d2 air suspension:
https://www.instagram.com/king_geo/
https://www.instagram.com/bagged_blackbenz/
and my buddy Phil has a 4Matic w D2:
https://www.instagram.com/netflixxandphil/
I am running the following for my air suspension:
*D2 Air Suspension (air struts) - the rear bags that came with the D2 kit was the short bags and was leaking on me. So I ended up contacting AirRex and got the triple bellow rear bags that they carried. This was a while back, I know Air Rex has partnered up with D2 to make their air bags now, so maybe you won't have this issue. Anyways, on our cars, the rear suspension is kinda weird because the bags/spring part is independent from the shock absorbers. They are not a single unit, they actually sits next to each other.
*Ridetech AirPod RidePro - This is what I am using for management. This kit comes with all the parts already mounted together. I had this already from another car, so I didn't use the D2 stuff. D2's management may be okay, but I've never used it, so I can't speak on it.
*If your car is bone stock and it doesn't have 4matic badging, then it's not 4matic.
