Question about tires
I picked the DWS 06 and had them installed. I had Pirelli Nero's on before and now I am finding my suspension "softer" in turns and ride then it was before.
I am reading more about the symptoms after the fact and I now feel I might have mad the wrong choice. I should have went with the A/S 3+.
I want a quite ride, tight cornering and good all weather performance (including snow). It seems like although the older A/S 3 were not good in the snow. The 2016 updated A/S 3 Plus are much better and the 2015 updated DWS 06 are lagging behind.
Since the got the tires at Town Fair Tires. I still have 30 days from date of purchase to change the tires without any cost. I need advice as to if I should go with the A/S 3+ or should I stick with the DWS 06.
DWS PROS
- longer life on DWS (25 - 27K miles)
- known snow traction
DWS CONS
Soft cornering and ride
A/S 3+ PROS
Excellent Dry and wet traction
Tighter cornering ability
A/S 3+ CONS
Possibly less snow traction
shorting life (22K - 24K miles)
Sears is the only tire dealer that has every honored a manufacturer’s warranty.
I find the tires a stiffer than the Conti contacts that came with the car. In the snow they work great, I travel from Hartford to Litchfield over Avon Mountain and they have gotten me home every time. I travel before the plows and after everyone has gotten home I like the tires but the mileage you get sucks.
Are you SURE the Michelins would corner better just like are you SURE the Continentals will last longer? Or are you just basing that on some reviews you have read? If I guess where I am going is if you do too much research you start getting paralysis by analysis and will constantly second guess your decision. If you are that unhappy and can change over without any cost to you, go for it.
I am basing my info mostly on a tirerack review which was done specifically between these tires. You can check the review here. http://www.tirerack.com/tires/tests/...y.jsp?ttid=216
Thanks for the update. I just went from the OE Pirellis to the DWS 06 and I find the DWS 06 soft while cornering. Traction is great but wondering if the AS 3+ are better.
