wrong bulb
Old Feb 26, 2017 | 09:42 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
wrong bulb
dealer replaced a low beam
it seems more yellow than the other one, could it be that they put the wrong bulb? Or does it need time to heat up or something? Its had time but idk.
Old Feb 27, 2017 | 01:03 AM
aamirani's Avatar
2011 C300 4MATIC
Color could change over time I believe
Old Feb 27, 2017 | 11:17 AM
white46's Avatar
08 C300
^ Yes. Output color changes over time. To maintain the same color output, you need to replace both bulbs at the same time.
Old Feb 27, 2017 | 01:22 PM
edgalang's Avatar
Factory ordered 2012 MB C350 w/Dynamic Handling Package
^x2 This is why I always replace headlight bulbs in pairs.
Old Feb 27, 2017 | 01:55 PM
Adi-Benz's Avatar
Sounds good. Thank you everyone for your help!
Old Feb 28, 2017 | 03:13 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
FWIW, mostly the color change thing is with HID lamps. With halogens, not so much, though they do fade. Your car has halogens from the photo. Just pop a new one in the other side and you'll be good to go.
Old Feb 28, 2017 | 10:24 AM
Adi-Benz's Avatar
I thought halogens were the big reflective ones?
yea i have hids, my lights are white/blue.
Old Feb 28, 2017 | 05:26 PM
LILBENZ230's Avatar
The pre-facelift cars had projectors regardless of HID or halogen, though if you look closely the units look different. Your car had halogens from the factory, and unless you've put HID in (which you would know?) it had halogens when you bought it based on your introduction photo:
https://mbworld.org/forums/c-class-w...ml#post6772247
They are similar, but a close look reveals differences. Also, HID equipped cars have headlamp washers and rear LED turn signals from 2008-2011.
Old Feb 28, 2017 | 06:40 PM
Adi-Benz's Avatar
Yea but my pictures come out yellow but IRL they are blueish. Which the previous owner could have put em in but idk.
At least projectors look good lol you are right cause I don't have washers.
Old Mar 2, 2017 | 04:59 AM
LILBENZ230's Avatar
So just pop in a new bulb on the other side and they'll match. If the car had an aftermarket HID kit, the dealer would have said it needed thousands of dollars in work and refused to touch it.
